tophershane 7 Posted June 29, 2025 Posted June 29, 2025 I built a tool for my own use to create better playlists for background viewing, and it's evolved a bit since then. I'm sharing it in case anyone else finds it useful. It's called MixerBee, and it can create interleaved TV mixes, movie playlists from filters, schedule them to update automatically and more. It also has an optional AI feature. The project is on GitHub if you want to give it a try. https://github.com/tophers/MixerBee 4 3
Elenthil 4 Posted July 8, 2025 Posted July 8, 2025 Great tool, it helps a lot for generating playlists for tv-shows. Who ever trys to make playlists for Arrowverse, Chicagoverse and other big Show universes should try MixerBee.
feerlessleadr 173 Posted August 15, 2025 Posted August 15, 2025 Thanks for sharing this. I just tried to setup my emby instance, but am getting an error. I created an issue on your github @tophershane
Painkiller88 250 Posted October 11, 2025 Posted October 11, 2025 really thanks for the tool. I have one thing i would really like to see in an upcomming update. A new Filter for the age control Thanks a lot.
ryzen5000 17 Posted January 18 Posted January 18 Thanks for sharing Mixerbee, I installed it on unraid recently and its working well, I would be cool to have Ollama integration at some point for Ai.
