Halliphax 4 Posted June 29, 2025 Posted June 29, 2025 Hello, I've recently started sharing my Emby server with friends and family. There are some custom Collections I don't wish to share with other users so I've tried using the tagging function to accomplish this but it doesn't appear to be working as I expect. Here's what I'm doing: Right-click and edit metadata on the chosen collection (in this example the 28 Days/Weeks Later Collection) Add whichever tags I choose, in this case "Hide" and "PersonalCollection" (I've tried both and one or the other but same result) Head over to the chosen user (in this example TestUser) and go to the Parental Control tab Add both tags; "Hide" and "PersonalCollection" Expected Behaviour: When logged in as TestUser and navigating to the Collections library, I would expect the 28 Days/Weeks Later Collection to no longer be visible Actual Behaviour: When logged in as TestUser and navigating to the Collections library the 28 Days/Weeks Later Collection is fully visible and can be interacted with (i.e items played) Is this a bug or am I misunderstanding the feature? I've tagged thousands of individual items (i.e individual episodes) as well as movies for use with VirtualTV and these work just fine - tagging Collection "items" themselves doesn't appear to work for me. Attached Emby Server log where I've added tags to the Collection item, to the user and accessed the Collection as the restricted user. Let me know if I need to/can provide anything else - thanks! embyserver (1).txt
Halliphax 4 Posted June 29, 2025 Author Posted June 29, 2025 Just to add: I realise a playlist can technically do what I'm attempting. However, a playlist will show episodes as individual items so it quickly becomes unwieldy with thousands of items. To clarify, I'm only looking to hide the Collection item, not the films within them if that makes sense (for context, myself and my partner keep a Collection as a sort of archive/list of the stuff we've watched together or have yet to watch - this is obviously irrelevant to other users so wanted to hide the Collection item, not the movies or shows that are contained within it).
Luke 42287 Posted August 1, 2025 Posted August 1, 2025 @Halliphaxcurrently collections are not personal although it is a possibility for future updates. For now I would consider using playlists instead. Please let us know if this helps. Thanks.
Halliphax 4 Posted August 2, 2025 Author Posted August 2, 2025 So is the tagging function working as expected then? I’ve tagged a collection with “Hide” and blocked that tag on user profiles but it’s still visible to them.
Luke 42287 Posted August 8, 2025 Posted August 8, 2025 On 8/2/2025 at 9:50 AM, Halliphax said: So is the tagging function working as expected then? I’ve tagged a collection with “Hide” and blocked that tag on user profiles but it’s still visible to them. Hi, do you mean the tag itself?
Halliphax 4 Posted August 12, 2025 Author Posted August 12, 2025 On 09/08/2025 at 06:35, Luke said: Hi, do you mean the tag itself? So as it stands - you can add tags to collections but as far as I can tell the tags don’t actually do anything at that level. As you can see from the logs, I blocked a tag in the parental control section of a user account but that user account could still see the Collection when they logged into Emby. Shouldn’t the expected behaviour here be that the account cannot see the collection as it has been given a tag that is blocked via parental controls?
Solution Luke 42287 Posted August 12, 2025 Solution Posted August 12, 2025 Collections skip that and are based on whether or not a user has access to any of it's items. 1
Neorun 0 Posted January 13 Posted January 13 On 8/13/2025 at 12:07 AM, Luke said: Collections skip that and are based on whether or not a user has access to any of it's items. Hi, is there a eta on this feature or any other way to hide collections from users? Id also be fine with me being the only user that can see collections at all.
Luke 42287 Posted January 13 Posted January 13 16 hours ago, Neorun said: Hi, is there a eta on this feature or any other way to hide collections from users? Id also be fine with me being the only user that can see collections at all. Do the users have access to the items within the collection?
