wolfram84 10 Posted June 26, 2025 Posted June 26, 2025 I've being doing this for ages, same USB, same process, delete the contents replace the userwidget folder delete the app from the app menu and plug the USB... Today I had a strange message "emby.tmg couldn't be installed because of expiration date" Something changed? I've tried resetting my TV but still having the same error...the latest version is from 05/26 today is 06/26 dunno if this is related as this thing never happened before even with older versions...
wolfram84 10 Posted June 26, 2025 Author Posted June 26, 2025 S90C Brazil, formatted the USB again as FAT32, transferred the latest version and got the same error msg, "emby.tmg couldn't be installed because of expiration date"
Solution FrostByte 5453 Posted June 26, 2025 Solution Posted June 26, 2025 (edited) 4 hours ago, wolfram84 said: I've being doing this for ages, same USB, same process, delete the contents replace the userwidget folder delete the app from the app menu and plug the USB... Today I had a strange message "emby.tmg couldn't be installed because of expiration date" Something changed? I've tried resetting my TV but still having the same error...the latest version is from 05/26 today is 06/26 dunno if this is related as this thing never happened before even with older versions... As SamES mentioned in the other thread they are a little bit late getting this month's app out. As you noticed the latest version on GitHub was compiled and uploaded on May 26. Each usb update expires 30 days after compiling. Once Luke compiles a new version then you can download and update. Edited June 26, 2025 by FrostByte
