Happy2Play 9812 Posted October 1, 2025 Posted October 1, 2025 Just now, yocker said: Maybe, the wording to me sounds like users won't be able to change quality at all with the setting though. Good point, dev may need to elaborate more here if it is overriding Auto or all Client configured quality settings. 1
Neminem 1623 Posted October 1, 2025 Posted October 1, 2025 There needs to be a better wording to this, this setting is confusing. I have to ask the big 3 questions like a 6 year old. How does is work ? Where does it work ? When does it work ? It's not spelled out, when to apply or why.
yocker 1414 Posted October 1, 2025 Posted October 1, 2025 (edited) I tried to force the setting to appear in Emby but it doesn't seem to do anything, at least not yet. The feature is most likely not finished. Edited October 1, 2025 by yocker
GrimReaper 4897 Posted October 1, 2025 Posted October 1, 2025 (edited) LOL we all have different interpretation of it. Based on the option text: "Allow transcoding to reduce quality, based on the app quality setting..." I would assume - if disabled - it will override both Auto fallback and in-app user quality reducing, i.e. effectively only allowing native (and higher) bitrates. Edited October 1, 2025 by GrimReaper 1
yocker 1414 Posted October 1, 2025 Posted October 1, 2025 3 minutes ago, GrimReaper said: LOL we all have different interpretation of it. Based on the option text: "Allow transcoding to reduce quality, based on the app quality setting..." I would assume - if disabled - it will override both Auto fallback and in-app user quality reducing, i.e. effectively only allowing native (and higher) bitrates. That is how i understand it as well, effectively making it so users can't lower the quality if actually needed. 1
yocker 1414 Posted October 1, 2025 Posted October 1, 2025 Oh well.. For now i will just make all connections look as lan connections for Emby. Fixes the problem.
seanbuff 1356 Posted October 31, 2025 Posted October 31, 2025 On 27/09/2025 at 15:32, Luke said: A new user restriction is being added here. So now you'll be able to allow them to transcode based on supported media, but not based on their quality setting. Hi @Lukewhen can we expect to see this in the beta branch?
adminExitium 356 Posted October 31, 2025 Posted October 31, 2025 Any chance these can also be library-based or resolution-based? For example I am fine with 1080p transcodes but not with 4K transcodes (they may as well watch the 1080p copy instead), so if I could disable only 4K-source transcodes, it would be really helpful. 2
GrimReaper 4897 Posted October 31, 2025 Posted October 31, 2025 11 minutes ago, adminExitium said: if I could disable only 4K-source transcodes, it would be really helpful You already can.
adminExitium 356 Posted October 31, 2025 Posted October 31, 2025 I have a similar script but it's not very reliable. Some sessions simply can't be stopped and just get stuck transcoding, never mind the messages. I can kill the ffmpeg processes for those stuck sessions repeatedly and it eventually does stop but I would prefer if it never started at all.
Luke 42243 Posted November 2, 2025 Posted November 2, 2025 On 10/31/2025 at 5:02 PM, seanbuff said: Hi @Lukewhen can we expect to see this in the beta branch? We have been talking it over internally and it's going to be a little different from what I previously showed. Instead it's going to be a default remote auto quality per user, so that as long as they leave their quality setting on auto, you can control what that value will be. 3 4
em1_fans 3 Posted November 3, 2025 Posted November 3, 2025 16 hours ago, Luke said: you can control what that value will be. Sounds good. Will that list contain Direct play? I don't care if somebody is streaming at 10 or 20 mbps as long as they are not transcoding
Luke 42243 Posted November 3, 2025 Posted November 3, 2025 4 hours ago, em1_fans said: Sounds good. Will that list contain Direct play? I don't care if somebody is streaming at 10 or 20 mbps as long as they are not transcoding If you just want a complete block then you can already do that via user permissions.
seanbuff 1356 Posted December 1, 2025 Posted December 1, 2025 On 03/11/2025 at 06:54, Luke said: We have been talking it over internally and it's going to be a little different from what I previously showed. Instead it's going to be a default remote auto quality per user, so that as long as they leave their quality setting on auto, you can control what that value will be. @Lukeany idea when we can see this option in the beta branch? 1 1
yocker 1414 Posted December 1, 2025 Posted December 1, 2025 On 11/2/2025 at 8:54 PM, Luke said: We have been talking it over internally and it's going to be a little different from what I previously showed. Instead it's going to be a default remote auto quality per user, so that as long as they leave their quality setting on auto, you can control what that value will be. That's awesome and very much needed! 3 1
shadezero 3 Posted January 8 Posted January 8 On 12/1/2025 at 2:44 AM, seanbuff said: @Lukeany idea when we can see this option in the beta branch? I see it it the change log for 4.9.4.1-beta 1
Happy2Play 9812 Posted January 8 Posted January 8 13 hours ago, shadezero said: I see it it the change log for 4.9.4.1-beta In today's updated release 4.9.3.0 Add user option to set user's auto remote quality 1
