crusher11 1143 Posted June 19, 2025 Posted June 19, 2025 I have an automation through Home Assistant that's been working fine for weeks, but today threw the error "Error: Entity media_player.emby_embycon does not support action media_player.media_pause".
TeamB 2440 Posted June 19, 2025 Posted June 19, 2025 Nothing has changed in EmbyCon for months/years I don't know why it stopped working.
Luke 42237 Posted June 20, 2025 Posted June 20, 2025 Does Home assistant have any logs to help with troubleshooting?
crusher11 1143 Posted June 21, 2025 Author Posted June 21, 2025 On 6/21/2025 at 3:46 AM, Luke said: Does Home assistant have any logs to help with troubleshooting? Only this: Logger: homeassistant.components.automation.emby_ugoos_playback_start Source: components/automation/__init__.py:738 integration: Automation (documentation, issues) First occurred: 4:46:51 AM (1 occurrences) Last logged: 4:46:51 AM Error while executing automation automation.emby_ugoos_playback_start: Entity media_player.emby_embycon does not support action media_player.media_pause
Luke 42237 Posted June 23, 2025 Posted June 23, 2025 On 6/21/2025 at 4:49 PM, crusher11 said: Only this: Logger: homeassistant.components.automation.emby_ugoos_playback_start Source: components/automation/__init__.py:738 integration: Automation (documentation, issues) First occurred: 4:46:51 AM (1 occurrences) Last logged: 4:46:51 AM Error while executing automation automation.emby_ugoos_playback_start: Entity media_player.emby_embycon does not support action media_player.media_pause And the server log from the same time?
crusher11 1143 Posted June 25, 2025 Author Posted June 25, 2025 On 6/24/2025 at 7:26 AM, Luke said: And the server log from the same time? embyserver.txt
Luke 42237 Posted June 27, 2025 Posted June 27, 2025 Nothing obvious there. Is home assistant able to do the same command on Emby apps?
crusher11 1143 Posted June 27, 2025 Author Posted June 27, 2025 17 minutes ago, Luke said: Nothing obvious there. Is home assistant able to do the same command on Emby apps? It's still working fine on the standard Android app. Was working fine with EmbyCon previously . If I try to add a 'play or pause command to a Home Assistant automation, it no longer even includes EmbyCon on the list of entities I can ap' apply it to.
crusher11 1143 Posted July 1, 2025 Author Posted July 1, 2025 On 6/28/2025 at 4:23 AM, Luke said: OK that's interesting, thanks. It's evidently reporting different compatibility to what it was when I first set it up, though I've no idea why. 1
TeamB 2440 Posted July 1, 2025 Posted July 1, 2025 8 hours ago, crusher11 said: It's evidently reporting different compatibility to what it was when I first set it up, though I've no idea why. it looks like you are using the Beta server (4.9.1.1) have you tried it with 4.8 stable?
crusher11 1143 Posted August 24, 2025 Author Posted August 24, 2025 This has been resolved at some point.
