Micha75 5 Posted June 15, 2025 Posted June 15, 2025 ich nutze für die Clienten die Amazon FireTV Sticks. Die sind ja eigentlich ok und Emby läuft gut damit. Bekannterweise kann mal aber bei den Sticks den Bildschirmschone/Energieeinstellungen so nicht ändern, bzw. nur mit PC und Tools. Wenn ich ein Film oder eine Serie schaue, alles prima. Höre ich aber Musik über Emby, dann springt der Stick irgendwann in den Modus, Bildschirm wird schwarz, und später, durch den Energie/Ruhemodus wird die Wiedergabe in Emby beendet und ich befinde mich dann auf dem Startscreen vom Amazonstick. Kann man in Emby irgendwas entgegenwirken damit der Stick das als Stream ansieht und der Ruhemodus nicht einsetzt? Gruß Micha
ebr 16332 Posted June 15, 2025 Posted June 15, 2025 Hi. What version of the app are you using on the stick?
Micha75 5 Posted June 15, 2025 Author Posted June 15, 2025 (edited) Hi ebr Emby for Android 3.4.74 Edited June 15, 2025 by Micha75
FrostByte 5452 Posted June 27, 2025 Posted June 27, 2025 Yes, similar with 3.4.76 on the Shield The screen saver will start when playing music and then some keys will not work anymore. I can scroll left/right and back, but up/down doesn't work once the SS kicks in. I normally have the SS set to 2 hours for this reason. I set it to 5 mins to test though
FrostByte 5452 Posted June 28, 2025 Posted June 28, 2025 I'll also add that in the Android settings where you set the time for the SS that there is a checkbox to not start SS while playing music. However, Emby seems to ignore this setting and starts its SS anyway. If Emby recognizes the time to start the SS, then I would think it could also read the Android setting to not play during music. That would be nice. I know it's the Emby SS (and not Android) because it's displaying my Emby photos which I've told Emby to do.
Luke 42239 Posted July 17, 2025 Posted July 17, 2025 @@Micha75 in Fire TV settings there is an option called Sleep Mode Behavior. Try setting this to Black Screen and see if that resolves your issue. Thanks.
Micha75 5 Posted July 19, 2025 Author Posted July 19, 2025 Guten Morgen @Luke Leider ist die Option nicht mehr da. :( Pech gehabt :) Trotzdem daanke
pektoral 22 Posted July 19, 2025 Posted July 19, 2025 Hi Micha, die einzige Lösung für dein Problem findest Du hier: https://iotdiy.com/how-to-turn-off-sleep-mode-on-fire-tv-stick/ Es gibt keinerlei Option in den Einstellungen des Firesticks die dieses Problem behebt. Nutze diesen selber zur Audio Wiedergabe über Emby... So good luck. Pektoral
pektoral 22 Posted July 19, 2025 Posted July 19, 2025 Zusatz: Ich habe 2 Firesticks so gepachted, funktioniert ohne Aussetzer bei der Audio only Wiedergabe. Der Screensaver ist hier sicher nicht das Problem sondern der nicht abschaltbare Sleep Mode des Sticks. (nicht möglich über die Optionen) Per ADB kannst Du das aber simpel regeln... Pektoral
Micha75 5 Posted July 19, 2025 Author Posted July 19, 2025 Nutze jetzt das Tool Wakelock apk. Das hindert den Stick daran in den Sleep-Modus zu wechseln. Besten Dank Gruß Micha
Luke 42239 Posted July 19, 2025 Posted July 19, 2025 12 hours ago, Micha75 said: Guten Morgen @Luke Leider ist die Option nicht mehr da. Pech gehabt Trotzdem daanke What do you mean by no longer available?
Micha75 5 Posted July 27, 2025 Author Posted July 27, 2025 On 7/19/2025 at 9:51 PM, Luke said: What do you mean by no longer available? Amazon hat in der Firmware mittlerweile die Option abgestellt. Man kann im Stick nichts mehr einstellen was mit Energie Optionen zusammenhängt. 1
