dudeskin 1 Posted June 12, 2025 Posted June 12, 2025 Hello, I am using hardware acceleration for transcoding which works spot on, but I don't have the option for hardware Tone mapping? Just software. Server Specs: Windows CPU: I7 9700 GPU: RX 570 4GB I presume it's because my hardware doesn't support it? Would anyone be able to help? Cheers! ffmpeg-transcode-227b54e9-4246-497e-9fac-d3d927e11363_1.txt
Solution GrimReaper 4928 Posted June 12, 2025 Solution Posted June 12, 2025 On 2/7/2024 at 1:56 PM, Luke said: Hi, You have an AMD Radeon Graphics and there's no hardware tone mapping support for AMD GPUs. AFAIK that's hasn't changed.
Luke 42301 Posted June 12, 2025 Posted June 12, 2025 HI, we'll have an updated ffmpeg build on the server beta channel in the near future, so stay tuned.
dudeskin 1 Posted June 12, 2025 Author Posted June 12, 2025 (edited) OOOH i look forward to that!! For the time being i've enabled the intergrated gpu on CPU in BIOS to get it to work. as a workaround for time being. So GPU is priority but anything it cant do, it dumps it to the CPU to do. Thank you! Edited June 12, 2025 by dudeskin 1
RanmaCanada 503 Posted June 13, 2025 Posted June 13, 2025 8 hours ago, dudeskin said: OOOH i look forward to that!! For the time being i've enabled the intergrated gpu on CPU in BIOS to get it to work. as a workaround for time being. So GPU is priority but anything it cant do, it dumps it to the CPU to do. Thank you! Just a heads up, your integrated graphics are far superior to your video card in regards to transcode speed and quality. Intel Quicksync is the king when it comes to these things. If you do insist on using a graphics card I would suggest you just get an Arc A310 or A380 and ditch the ancient Polaris space heater. 1
dudeskin 1 Posted June 13, 2025 Author Posted June 13, 2025 Yeah - to be honest i hardly use transcoding it's 99% direct play but the GPU was a good deal thats the only reason i have it lol
KarlDag 25 Posted June 18, 2025 Posted June 18, 2025 (edited) On 12/06/2025 at 13:55, Luke said: HI, we'll have an updated ffmpeg build on the server beta channel in the near future, so stay tuned. Hey Luke, Sorry to hijack the thread but I googled, searched forums and the support section of the website - I can't find a support article / matrix for tone mapping. What platforms is it supported on? What OSes? Also, I currently use an AMD 7800XT on Linux, in docker. It seems to be doing hardware transcoding, and tone mapping somehow. Is it done in software in a different step? Can it be that it's being done with VAAPI? I'd love more documentation on this. Thanks, Edited June 18, 2025 by KarlDag
Guest Posted June 19, 2025 Posted June 19, 2025 On 6/12/2025 at 1:00 PM, dudeskin said: OOOH i look forward to that!! For the time being i've enabled the intergrated gpu on CPU in BIOS to get it to work. as a workaround for time being. So GPU is priority but anything it cant do, it dumps it to the CPU to do. Thank you! Disabling the gpu at the BIOS will often lead to Windows not loading some GPU drivers. It isn't recommended to do that.
