Blacky_0815 0 Posted May 30, 2025 Posted May 30, 2025 i'm trying since weeks different m3u files for entertain. i made now a playlist with the adresses which shown in the playlist of my Fritzbox. if i open the playlist on my pc with vlc, it works. if i import it on emby equal if livetv or the plugin, it will not work. in the log there's ffmpeg and ffprobe. but i can't find the problem by myself. i hope you can help me. The Problem was also in the latest version which is delivered at the synology app store. then i manually updated it with the file from your site to the newest version. Error Message said only, no valid stream. Now the informations which are required: Synology DS918+ DSM 7.1.1-42962 Update 8 Emby Server Version 4.8.11.0 EmbyPremium is active. if i have to open a new topic i will make it, but i thought, if there is already a topic which is matching i will try it there first. thanks for your help Blacky emybserver_log.txt ffmpeg-transcode-062fd0de-0166-41db-ad59-74c9804304f7_1.txt
Luke 42241 Posted June 12, 2025 Posted June 12, 2025 @Blacky_0815 are you still having an issue with this?
Blacky_0815 0 Posted June 12, 2025 Author Posted June 12, 2025 @Lukeyes. I also bought an DVB-S2 to IP Tuner and tried it with DVBViewer. There only the not HD Streams working at the Windows App, at the Browser it is also not working. With Entertain nothing is working.
bronoo1 0 Posted July 8, 2025 Posted July 8, 2025 To use an M3U file, just copy the M3U URL and paste it into an Iplayer like VLC, IPTV Smarters, . It will automatically load the channels listed in the file. No need to download anything — just stream directly from the link.
