Peter Nent 71 Posted June 10, 2025 Posted June 10, 2025 I thought that this issue was fixed in an erlier version op EMBY UI, but its not fixed/still an issue: When scrolling using the Remote Control (RC), vertically through the EPG if live-TV is visible at the background, the scrolling mostly spontaneous continues allthough the up or down key on the RC is not pressed anymore. This unwanted response contineous and is very anying..... If live-TV is stopped, this contineous scrolling doesn't happen.....thus it seems to be related to live-TV on the background of the EPG.... Could this be fixed ? Thanks & grtz. Peter
Luke 42237 Posted June 10, 2025 Posted June 10, 2025 Hi, is this a question about Softworkz's wmc app?
softworkz 5133 Posted June 23, 2025 Posted June 23, 2025 On 6/10/2025 at 9:02 PM, Peter Nent said: I thought that this issue was fixed in an erlier version op EMBY UI, but its not fixed/still an issue: When scrolling using the Remote Control (RC), vertically through the EPG if live-TV is visible at the background, the scrolling mostly spontaneous continues allthough the up or down key on the RC is not pressed anymore. This unwanted response contineous and is very anying..... If live-TV is stopped, this contineous scrolling doesn't happen.....thus it seems to be related to live-TV on the background of the EPG.... Could this be fixed ? Let's collect all the open issues and when I find some time (or I'm annoyed by all other priority work), I'll try to nail as much as possible at once. You can help by filing and organizing the open issues here: https://github.com/EmbySupport/Emby.WMC.UI/ (under "Issues"). That's still the place I'll be looking at. Please make sure to create singular issues (not combiining multiple into a single one). You can just copy/paste texts from the forums (but separate accordingly). Thanks
