fricelander 14 Posted June 10, 2025 Posted June 10, 2025 Hi, I have Emby server on windows and I was wondering if it's possible to run it on 2 ports ? basically I've changed Emby port to 80 to have a clean url when accessing via web browser but then I have to add :80 when connecting through the app, is there a setting on Emby or should I check on the router side ?
Luke 42301 Posted June 10, 2025 Posted June 10, 2025 Hi, there currently is no option for two http ports. The server can use two ports, but one is for http and the other is for https. What you might be able to do is keep Emby on default ports, but then also setup an extra port forwarding rule in your router to forward port 80 to 8096.
fricelander 14 Posted June 11, 2025 Author Posted June 11, 2025 Hi, it's not about http/https, the default emby port is 8096, but I don't want to have the port in my url while accessing from a web browser so I've set up to 80, now on web browser it's fine but when I'm accessing through emby app on iPhone or other device the app is set to try the server url on port 8096 but now cause I'm in port 80 I have to put my server URL:8096 on app is there a way that I don't have to put any port from web and app ?
Luke 42301 Posted June 11, 2025 Posted June 11, 2025 1 hour ago, fricelander said: is there a way that I don't have to put any port from web and app ? Yes you can blank out the port when you are entering the server connection information.
fricelander 14 Posted June 11, 2025 Author Posted June 11, 2025 HI, Thanks for your answer but I don't get it ? What am I supposed to do ?
Solution seanbuff 1360 Posted June 11, 2025 Solution Posted June 11, 2025 4 minutes ago, fricelander said: What am I supposed to do ? Did you try this? 10 hours ago, Luke said: you can blank out the port when you are entering the server connection information 1
