DML1986 0 Posted June 10, 2025 Posted June 10, 2025 Hello, with 3.4.72 (Amazon store) there seems to be an issue in regards of transcodeing. Transcodeing starts normally but exits after a coupple of minutes and then starts a new transcode. This is bundled with some weird behaveior on the overview page, where you can see the connected clients and its watch (green) and transcodeing (red) progressbar. The transcodeingbar is missing and the other fields look as if they wanted to show transcode infos but have whitespace instead. On the client if you check for nerd details it says its direct playing, however, this also seems to be false because if i set quality to for example 144p i really get 144p but the client still reports direct playing. I verified this by deleting the app and going back to 3.4.70 without those issue but comes back with 3.4.72. Havent tested google version yet but i guess the differences to amazon version are close to non existant in regards to this.
Luke 42243 Posted June 10, 2025 Posted June 10, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
DML1986 0 Posted June 13, 2025 Author Posted June 13, 2025 (edited) Whatever you did, in 3.4.74 it looks like its fixed. Thanks! BUT... coincidentally while looking for logs i figured the "anonymize logs" switch has no effekt?!? Every path and url remains cleartext. Server 4.8.11.0 docker Tested on Firefox and Edge Edited June 13, 2025 by DML1986
Luke 42243 Posted June 13, 2025 Posted June 13, 2025 11 minutes ago, DML1986 said: Whatever you did, in 3.4.74 it looks like its fixed. Thanks! BUT... coincidentally while looking for logs i figured the "anonymize logs" switch has no effekt?!? Every path and url remains cleartext. Server 4.8.11.0 docker Tested on Firefox and Edge HI there, can you please provide a specific example? How to Report a Problem Thanks !
