justinrh 266 Posted June 7, 2025 Posted June 7, 2025 Suddenly, a few channels are missing guide data. I've never seen happen before for these channels in ZIP 35810. 48.3 and I asked about the new 48.7 channel in another thread.
justinrh 266 Posted June 8, 2025 Author Posted June 8, 2025 After a couple of days it corrected itself. Those channels are not populated.
sa2000 695 Posted June 9, 2025 Posted June 9, 2025 (edited) 3 hours ago, justinrh said: After a couple of days it corrected itself Sometimes schedules may be late- did you try a guide refresh when the schedules were not showing ? I can see now there are schedules of airings for the 3 channels for the period of the guide you highlighted 48.5 GRIT 54.2 MNT 54.9 COMET 3 hours ago, justinrh said: Those channels are not populated. You mean they were not populated before the problem corrected itself. They are ok now? Edited June 9, 2025 by sa2000
justinrh 266 Posted June 9, 2025 Author Posted June 9, 2025 (edited) 20 hours ago, sa2000 said: did you try a guide refresh when the schedules were not showing Yes - it did not help. Yes, those channels are okay now. Typo above Edited June 9, 2025 by justinrh 2
