heyimdaf 0 Posted June 5, 2025 Posted June 5, 2025 Hi all, setting up my Emby server on my Docker setup on Ubuntu 24.04 - using the attached Docker compose file. docker-compose.yml I want to use Emby with my HDHomerun, so have activated an Emby Premiere subscription, saved it in the config, and added my HD Homerun tuner. I went to set up guide data using Emby Guide data, and every time I try and enter my postcode (Belfast, BT2 area, UK), I get this error: I've attached the anonymised log: embyserver(1).txt Key errors seem to be around line 432. Cheers!
Abobader 3485 Posted June 5, 2025 Posted June 5, 2025 Hello heyimdaf, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
heyimdaf 0 Posted June 5, 2025 Author Posted June 5, 2025 (edited) n.b posted in general forum as it's a Docker installation, and I can't see a Docker category. I have a feeling some of the auth errors will just be clients that are currently running the Jellyfin app as it polls the same port, as I'm migrating away from it to Emby if the integration goes well. Edited June 5, 2025 by heyimdaf
Luke 42243 Posted June 9, 2025 Posted June 9, 2025 Hi, does your zip code contain a dash? if so, then try using either the first half or last half of it separately and see if that helps.
