Goatmaster 3 Posted June 5, 2025 Posted June 5, 2025 Hi everyone, I installed the M3U TV Tuner plugin from the Emby plugin catalog, then restarted my server as expected. However, when I go to Live TV > Tuners, I don’t see any section or option for "M3U TV Tuner". My goal is to load an M3U playlist, but only import specific channel groups, not the entire list. Right now, I can’t even reach the point where I can configure the tuner. Steps I followed: Installed "M3U TV Tuner" plugin Restarted Emby server Went to Live TV settings, but nothing new appears under Tuners Is there something I’m missing? Should I configure it somewhere else first before it shows up under Live TV? Any help would be appreciated! Thanks in advance
Goatmaster 3 Posted June 5, 2025 Author Posted June 5, 2025 I did i only see these options: I also have installed M3U TV tuner, but also can still install it from the catalog:
Goatmaster 3 Posted June 5, 2025 Author Posted June 5, 2025 3 minutes ago, Luke said: And did you try clicking M3U? yes i did i get the next error:
Luke 42241 Posted June 5, 2025 Posted June 5, 2025 No, I mean in your first screenshot up above. Add TV Source -> M3U.
