r5yk5 12 Posted June 3, 2025 Posted June 3, 2025 Does anybody know why I can no longer connect to emby using my external ip address while I'm connected to my home network? I can connect remotely when I'm remote. It's causing an issue using Synfonium. Also I need to bookmarks in my laptops browser now. I don't think it's my router because I just set up a different media server that uses upnp to automatically forward the ports and that works fine. Thanks.
Happy2Play 9814 Posted June 3, 2025 Posted June 3, 2025 (edited) Since you can connect Remotely Emby and router are configured correctly. Most likely a Router issue as most home routers will not allow hairpin loopbacks. I know on my Linksys route I cannot connect to my WAN address on my LAN. Edited June 3, 2025 by Happy2Play
r5yk5 12 Posted June 3, 2025 Author Posted June 3, 2025 Maybe my router updated itself. It has worked fine for a long time but has suddenly stopped.
Luke 42301 Posted June 3, 2025 Posted June 3, 2025 Quote Does anybody know why I can no longer connect to emby using my external ip address while I'm connected to my home network? Hi there, what exactly happens when you try?
Solution Luke 42301 Posted June 3, 2025 Solution Posted June 3, 2025 Quote Most likely a Router issue as most home routers will not allow hairpin loopbacks. Right, nowadays most routers don't allow this, so for most users I would not expect it to work anyway.
