ppoppojoa 1 Posted June 3, 2025 Posted June 3, 2025 HI. I downloaded the file from the link today. https://github.com/MediaBrowser/Emby.Releases/raw/master/tizen/tizen.zip and tried to install it on my Samsung TV, but unlike before, the installation did not work and an error log message occurred. The following error log remains in the ses-usb-installer.log file. [06-03 09:32:56/7179] SES path not found, exit ses-usb-installer.log
SamES 1084 Posted June 3, 2025 Posted June 3, 2025 What model TV? How did you setup the USB drive? What format did you use? FAT32? BTW, what country are you in?
ppoppojoa 1 Posted June 3, 2025 Author Posted June 3, 2025 4 hours ago, SamES said: What model TV? How did you setup the USB drive? What format did you use? FAT32? BTW, what country are you in? I solved this problem. When I connected the USB, it was automatically installed without me realizing it, and I thought it wasn't installed, so I connected the USB repeatedly, but there was no response, so I checked the log saved in the USB. Then I found out that it was already installed. Thank you. ps. This is Korea. and TV model is Q60 series. 1
