B08853 1 Posted May 30, 2025 Posted May 30, 2025 The 8K HEVC video was recorded with a Samsung ZFold 4 - Will not play on Emby Theater, Android TV or Emby Web Player. All testing done here is on a Gigabit LAN using Ubiquiti UDM Pro Router. #1 Example - Playing video on Emby Server itself using the Emby Theater App Video does not play - Emby Theater App Playback settings on Auto Video and audio is very choppy - not watchable - Emby Theater App Playback settings to 360p #2 Example - Playing video on LAN - on Android TV Video does not play, just show a frozen picture and audio is very choppy - sometimes crashed the Emby App #3 Example - Playing video on LAN - on Windows PC using Emby Theater Video does not play and audio is very choppy - not watchable. #4 Example - Playing on LAN - on the Samsung ZFold 4 using Android App Video plays normally #5 Example - Playing on the Emby Server itself - http://localhost:8096/web Video plays normally See attached photos. Please advise.. I this a problem or a setting that I am missing?
GrimReaper 4928 Posted May 30, 2025 Posted May 30, 2025 (edited) That is high bitrate file, increase playback quality in your client apps to some numerical value higher than that bitrate (>=100 Mbps) so it'd DirectPlay (if you do have 8K display, else it'd have to be transcoded anyway), guess would be your server is not powerful enough to transcode those items in real-time, you can provide ffmpeg logs. Though that AndroidTV session Now Playing window looks odd. @Luke Edited May 30, 2025 by GrimReaper
B08853 1 Posted May 30, 2025 Author Posted May 30, 2025 Here are the ffmpeg logs - using Android TV and Emby Theater on the Emby Server PC at 360p. ffmpeg-transcode-6a8b0af8-5662-48b3-bb48-b6ad91ff56e7_1.txt ffmpeg-transcode-4cd8179c-8000-4a46-af42-1332c09ed9f4_1.txt ffmpeg-transcode-d865e00d-6e60-48a3-9c21-66f778a7f234_1.txt ffmpeg-transcode-1c30f0d5-9554-4566-99d1-93068f653b8a_1.txt ffmpeg-transcode-dee3e5eb-275f-4f7a-90ff-d5529d3000aa_1.txt ffmpeg-transcode-4bfd3763-7b9f-41ac-a3d0-1ec7a2895709_1.txt
GrimReaper 4928 Posted May 30, 2025 Posted May 30, 2025 (edited) As stated: 4 hours ago, GrimReaper said: guess would be your server is not powerful enough to transcode those items in real-time Don't know what kind of a machine your server is (CPU+GPU (if any)), but as no HWA, transcoding is done in software only and your CPU is simply not up to the task (not surprising, as for 8K HEVC 80 Mbps file you'd need a really powerful one): Quote >>>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: True, HWA-Mode: Disabled Info Checking: 'x264' Info Check successful - selecting 'x264' >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Disabled Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' Quote App: Emby Windows 2.234.2.0 EMBY-08853HP 11:06:23.968 elapsed=00:00:00.10 frame= 1 fps=0.0 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 11:06:24.339 elapsed=00:00:00.63 frame= 4 fps=0.0 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 11:06:24.976 elapsed=00:00:01.28 frame= 8 fps=6.2 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 11:06:25.611 elapsed=00:00:01.92 frame= 12 fps=6.2 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 11:06:26.243 elapsed=00:00:02.54 frame= 16 fps=6.3 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 11:06:26.922 elapsed=00:00:03.19 frame= 20 fps=6.3 q=0.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.314x 11:06:27.406 elapsed=00:00:03.71 frame= 23 fps=6.2 q=0.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.27x 11:06:27.820 elapsed=00:00:04.21 frame= 31 fps=7.3 q=28.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.238x 11:06:28.500 elapsed=00:00:04.80 frame= 37 fps=7.7 q=28.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.209x 11:06:28.960 elapsed=00:00:05.42 frame= 40 fps=7.4 q=28.0 size=N/A time=00:00:01.02 bitrate=N/A throttle=off speed=0.189x 11:06:29.727 elapsed=00:00:06.03 frame= 45 fps=7.5 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.332x 11:06:30.209 elapsed=00:00:06.65 frame= 49 fps=7.4 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.301x 11:06:30.992 elapsed=00:00:07.30 frame= 60 fps=8.2 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.275x 11:06:31.639 elapsed=00:00:07.94 frame= 64 fps=8.1 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.252x 11:06:32.157 elapsed=00:00:08.45 frame= 67 fps=7.9 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.356x 11:06:32.812 elapsed=00:00:09.11 frame= 71 fps=7.8 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.33x 11:06:33.189 elapsed=00:00:09.62 frame= 78 fps=8.1 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.312x 11:06:33.947 elapsed=00:00:10.25 frame= 85 fps=8.3 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.293x 11:06:34.404 elapsed=00:00:10.86 frame= 88 fps=8.1 q=25.0 size=N/A time=00:00:03.02 bitrate=N/A throttle=off speed=0.279x 11:06:35.172 elapsed=00:00:11.48 frame= 93 fps=8.1 q=28.0 size=N/A time=00:00:03.98 bitrate=N/A throttle=off speed=0.347x 11:06:35.763 elapsed=00:00:12.05 frame= 96 fps=8.0 q=28.0 size=N/A time=00:00:03.98 bitrate=N/A throttle=off speed=0.331x Quote App: AndroidTv 2.1.23g Desk TV 10:57:04.201 elapsed=00:00:00.10 frame= 1 fps=0.0 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 10:57:04.508 elapsed=00:00:00.66 frame= 4 fps=0.0 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 10:57:05.106 elapsed=00:00:01.26 frame= 8 fps=6.3 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 10:57:05.694 elapsed=00:00:01.85 frame= 12 fps=6.5 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 10:57:06.498 elapsed=00:00:02.46 frame= 16 fps=6.5 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 10:57:06.846 elapsed=00:00:02.97 frame= 19 fps=6.4 q=0.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.337x 10:57:07.521 elapsed=00:00:03.64 frame= 23 fps=6.3 q=0.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.275x 10:57:07.925 elapsed=00:00:04.15 frame= 27 fps=6.5 q=28.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.241x 10:57:08.505 elapsed=00:00:04.76 frame= 32 fps=6.7 q=28.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.211x 10:57:09.115 elapsed=00:00:05.37 frame= 37 fps=6.9 q=28.0 size=N/A time=00:00:01.00 bitrate=N/A throttle=off speed=0.187x 10:57:09.902 elapsed=00:00:06.04 frame= 42 fps=6.9 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.331x 10:57:10.426 elapsed=00:00:06.57 frame= 45 fps=6.8 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.305x 10:57:10.928 elapsed=00:00:07.08 frame= 48 fps=6.8 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.283x 10:57:11.508 elapsed=00:00:07.66 frame= 53 fps=6.9 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.262x 10:57:12.209 elapsed=00:00:08.35 frame= 58 fps=6.9 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.24x 10:57:12.914 elapsed=00:00:08.94 frame= 62 fps=6.9 q=28.0 size=N/A time=00:00:02.00 bitrate=N/A throttle=off speed=0.224x 10:57:13.282 elapsed=00:00:09.59 frame= 64 fps=6.7 q=28.0 size=N/A time=00:00:02.02 bitrate=N/A throttle=off speed=0.211x 10:57:13.998 elapsed=00:00:10.15 frame= 69 fps=6.8 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.296x 10:57:14.559 elapsed=00:00:10.81 frame= 73 fps=6.7 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.278x 10:57:15.106 elapsed=00:00:11.36 frame= 79 fps=7.0 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.265x 10:57:15.735 elapsed=00:00:11.92 frame= 83 fps=7.0 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.252x 10:57:16.441 elapsed=00:00:12.58 frame= 88 fps=7.0 q=25.0 size=N/A time=00:00:03.00 bitrate=N/A throttle=off speed=0.239x 10:57:17.119 elapsed=00:00:13.26 frame= 92 fps=6.9 q=28.0 size=N/A time=00:00:03.98 bitrate=N/A throttle=off speed=0.301x 10:57:17.668 elapsed=00:00:13.78 frame= 95 fps=6.9 q=28.0 size=N/A time=00:00:03.98 bitrate=N/A throttle=off speed=0.289x With speeds up to 0.3x max, no real-time transcoding is even remotely possible (you need >=1.0x as an absolute minimum). You can either: 1) Upgrade server machine (CPU/iGPU/dGPU) or replace it for/use a more powerful machine as your server, subscribe to Premiere so you'd get HWA or 2) Pre-convert media to a format that'll DirectPlay on your clients (you can use Emby's Convert feature) Edited May 30, 2025 by GrimReaper
Happy2Play 9814 Posted May 30, 2025 Posted May 30, 2025 (edited) Is 80Mbps the client max I would assume you have to manually apply the highest quality setting in the client as I don't believe any are defaulted that high. &VideoBitrate=79743984&AudioBitrate=256016 &TranscodeReasons=ContainerBitrateExceedsLimit But yes as Grim mentioned this hardware isn't really capable of transcoding this media. Did you set the client this low? Emby Windows 2.234.2.0 &VideoBitrate=272000&AudioBitrate=128000 Edited May 30, 2025 by Happy2Play 1
GrimReaper 4928 Posted May 30, 2025 Posted May 30, 2025 1 minute ago, Happy2Play said: Is 80Mbps the client max I would assume you have to manually apply the highest quality setting in the client Suggested previously: 4 hours ago, GrimReaper said: increase playback quality in your client apps to some numerical value higher than that bitrate (>=100 Mbps) so it'd DirectPlay (if you do have 8K display, else it'd have to be transcoded anyway) Wild guess would be no 8K displays attached to those clients. 1
B08853 1 Posted May 31, 2025 Author Posted May 31, 2025 Thank you for your help. The PC is a Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz 3.00 GHz - 24.0 GB - Windows 11 Pro I have Emby Premier - After enabling Hardware acceleration. The Windows Emby Theater now plays the video on the Emby Server. The Windows Emby Theater on a LAN PC plays the video. The Emby Web plays the video. But the Android TV does not play the video. It behaves the ssame. Any suggestions would be greatly appreciated. Thank you
B08853 1 Posted May 31, 2025 Author Posted May 31, 2025 I am have successfully converted the file using the Emby Convert Feature - I wasn't aware of this feature The video now plays on Android TV Thank you @GrimReaper & @Happy2Play Any other suggestions or comments are welcome - Thank you again..
Luke 42301 Posted June 2, 2025 Posted June 2, 2025 On 5/31/2025 at 1:05 AM, B08853 said: How can I get the video to convert to 4K? Hi, do you mean convert ahead of time, or during playback?
