EmbFinPlex 3 Posted May 28, 2025 Posted May 28, 2025 From searching the forums I can see that there are instances of users having multiple HDHomeRuns but couldn't find my specific scenario. I'm in the metro Detroit area where I can get OTA stations from Detroit, Windsor, and Toledo. Combing antennas is typically not a good experience so I was considering having an HDHomeRun for an antenna pointed towards Detroit and an HDHomeRun for an antenna pointed towards Toledo. Can the separate HDHomeRuns be be combined in Emby to get channels from both markets?
EmbFinPlex 3 Posted May 28, 2025 Author Posted May 28, 2025 27 minutes ago, Luke said: Hi, yes you can do this. Thanks for confirming. How does it work? As in, there will be some overlap in channels so can you select which channels to display from each device?
Sammy 791 Posted May 28, 2025 Posted May 28, 2025 3 hours ago, EmbFinPlex said: Thanks for confirming. How does it work? As in, there will be some overlap in channels so can you select which channels to display from each device? You'll have a separate EPG assigned to each tuner. There may be some overlap but you can disable channels and chose the stronger signal only. 1
richt 95 Posted May 28, 2025 Posted May 28, 2025 I also used the favorites function on the HDHomerun channel lineup page and then in Emby set each tuner to "Restrict to channels marked as favorite". This prevents a lower signal quality channel from inadvertently being used by Emby. 1
EmbFinPlex 3 Posted May 28, 2025 Author Posted May 28, 2025 Does having sperate EPG's mean that you'll have separate guides?
Sammy 791 Posted May 28, 2025 Posted May 28, 2025 Just now, EmbFinPlex said: Does having sperate EPG's mean that you'll have separate guides? No. You'll have them in sequential order though.
