Carlonchis 4 Posted May 25, 2025 Posted May 25, 2025 Hi. I'm facing same issue. While "remember audio" works as expected and changes the audio of all episodes when you change it in one, "remember subtitles" option doesn't work at all. No matter what subtitle mode you set, subtitles are not propagated to other episodes. Do we have any update to this topic? 2
Luke 42244 Posted May 26, 2025 Posted May 26, 2025 @Carlonchis Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Normanos 13 Posted May 26, 2025 Posted May 26, 2025 Yes, something is wrong with subtitles for very long time... . I found, if turn off "Remember subtitle track selections" it's not showing subs at all. Yes, then not playing. But even, if Subtitle Mode is "No subtitles", it's still playing forced subs. Generally I'm not using subs, but have rare need for them. embyserver (1).txt 1
Carlonchis 4 Posted May 26, 2025 Author Posted May 26, 2025 (edited) Current behaviour: Select Spanish in preferred audio language, remember choices as true (and click on Delete saved choices): Select English as preferred subtitle language, remember choices as true and "Smart" mode(and click on Delete saved choices): Go to shows and it's selected Spanish (in audio) and English (in subs): When I change Spanish audio to any other language, it is propagated to all episodes of the show: Edited May 26, 2025 by Carlonchis
Carlonchis 4 Posted May 26, 2025 Author Posted May 26, 2025 My previous post was mistaken. It can be deleted. Full post is: Current behavior: Select Spanish in preferred audio language, remember choices as true (and click on Delete saved choices): Select English as preferred subtitle language, remember choices as true and "Smart" mode(and click on Delete saved choices): Go to shows and it's selected Spanish (in audio) and English (in subs): (Wrong behavior: since Spanish is my preferred audio language, subs should be off) When I change audio to any other language except my preferred audio language (Spanish), it is propagated to all episodes of the show and my preferred subtitle language (English) is automatically set: When I change audio to English (my preferred subtitle language), it is propagated to all episodes of the show but subtitles are automatically set off: (Wrong behavior: my preferred sub language should be set to all episodes) When I have English as audio, no matter what changes I do over subtitles, they are not propagated embyserver.txt ffmpeg-transcode-22ed4bf4-fe00-4b7b-a612-1094802d67f8_1.txt
GrimReaper 4898 Posted May 26, 2025 Posted May 26, 2025 (edited) 1 hour ago, Carlonchis said: My previous post was mistaken. It can be deleted. Full post is: Current behavior: Select Spanish in preferred audio language, remember choices as true (and click on Delete saved choices): Select English as preferred subtitle language, remember choices as true and "Smart" mode(and click on Delete saved choices): Go to shows and it's selected Spanish (in audio) and English (in subs): (Wrong behavior: since Spanish is my preferred audio language, subs should be off) When I change audio to any other language except my preferred audio language (Spanish), it is propagated to all episodes of the show and my preferred subtitle language (English) is automatically set: When I change audio to English (my preferred subtitle language), it is propagated to all episodes of the show but subtitles are automatically set off: (Wrong behavior: my preferred sub language should be set to all episodes) When I have English as audio, no matter what changes I do over subtitles, they are not propagated AFAIK you're going backwards about it (the assumptions you start with are are based on interpretation opposite to current Emby's logic - by that I don't mean wrong by default, as helper text below subtitle mode is somewhat ambiguous, and, truth be told, maybe that should be the logic implemented, as there's pros and cons to both approaches - hence "interpretation"): you assume that language other than preferred audio language triggers Smart mode subtitle selection, while it's actually preferred subtitle language that does it, in cases where audio language is different from preferred subtitle language (I'd guess based on the assumption that Spanish-speaking person would have Spanish subtitles as preferred, not English). That's why you're seeing all the above behaviors: - any audio language other than English (which is preferred subs language) results in English subs pre-selected - English audio language (also preferred subs language) results in no subs/subs Off (you'd observe the same with Spanish/Spanish preferred) Edited May 26, 2025 by GrimReaper Typo
Carlonchis 4 Posted May 26, 2025 Author Posted May 26, 2025 Indeed, I misunderstood the behavior. Thanks for the clarification! Anyways, no matter what subs mode I select (and preferred audio and subs langs) , subs are not propagated So, how could I do if I want to: Spanish audio - no subs English audio - English subs I don't mind If it's not automatic, but at least, if I change subs in one episode, I want it to be propagated automatically Thanks in advance
GrimReaper 4898 Posted May 26, 2025 Posted May 26, 2025 (edited) 11 minutes ago, Carlonchis said: So, how could I do if I want to: Spanish audio - no subs English audio - English subs Not feasible in any of the currently available subtitle modes (unless you want to hack it and change all English subs to spa language code). 11 minutes ago, Carlonchis said: I don't mind If it's not automatic, but at least, if I change subs in one episode, I want it to be propagated automatically Simply selecting different track in the UI does not propagate any change nor it makes that selection stick/remembered (nor it ever did); for any change to default/automatic selection, item has to be played/started, even for few seconds, to be remembered. That also applies to remembering per-TV show feature. On 12/18/2023 at 3:18 AM, Luke said: This will be in Emby Server 4.8. How it Works: This requires that you enable remembering audio and subtitle track selections. this is enabled by default. The server will first check if you've previously played the video file, just like before, and if it has then it will use your previous track selections If not, then it will look at your last played episode of the same series and attempt to use the same audio and subtitle selections. Essentially it will take the languages of the tracks and put these languages at the front of the language priority list. Edited May 26, 2025 by GrimReaper
Carlonchis 4 Posted May 26, 2025 Author Posted May 26, 2025 1 hour ago, GrimReaper said: Simply selecting different track in the UI does not propagate any change nor it makes that selection stick/remembered (nor it ever did); for any change to default/automatic selection, item has to be played/started, even for few seconds, to be remembered. That also applies to remembering per-TV show feature. What I'm trying to say is that the remembering per-TV show feature is giving problems to me (IDK if it's a bug or it's simply me not making it work). I select English audio and English subs, I play the video (in all my previous examples I did not specify but I didn't just change in UI but play the video too) and audio is propagated to the whole show but subs are not. No matter what subs mode or language I choose. This is my real problem, subs are not being propagated
GrimReaper 4898 Posted May 26, 2025 Posted May 26, 2025 19 minutes ago, Carlonchis said: I select English audio and English subs, I play the video (in all my previous examples I did not specify but I didn't just change in UI but play the video too) and audio is propagated to the whole show but subs are not. No matter what subs mode or language I choose. This is my real problem, subs are not being propagated Dev will have to comment in that case. @Luke In the meantime, you might provide info/logs as previously requested: 14 hours ago, Luke said: @Carlonchis Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
ebr 16337 Posted May 26, 2025 Posted May 26, 2025 I believe we have determined there are issues with this in 4.8.x that have been addressed in the 4.9.x line. 1 2
Carlonchis 4 Posted May 26, 2025 Author Posted May 26, 2025 Nice, thanks for the info. I will look forward to version 4.9 1
