yaniv18764 0 Posted May 25, 2025 Posted May 25, 2025 Hello everyone, I would appreciate a little help. I have a problem that is being presented to me. Maybe you know how to solve it.
Gilgamesh_48 1244 Posted May 25, 2025 Posted May 25, 2025 18 minutes ago, yaniv18764 said: Hello everyone, I would appreciate a little help. I have a problem that is being presented to me. Maybe you know how to solve it. This should be in its own thread as it has nothing to do with the topic originally posted. However the message presented pretty much tells you the problem as it says you have exceeded you Premier device limit.
yaniv18764 0 Posted May 25, 2025 Author Posted May 25, 2025 I have one device, how can there be an exception because of one device? 5 minutes ago, Gilgamesh_48 said: This should be in its own thread as it has nothing to do with the topic originally posted. However the message presented pretty much tells you the problem as it says you have exceeded you Premier device limit.
Gilgamesh_48 1244 Posted May 25, 2025 Posted May 25, 2025 46 minutes ago, yaniv18764 said: I have one device, how can there be an exception because of one device? But what does it say on your server's device page? I am just a user but the actual knowledgeable people will be along to correct anything I say that is in error or wrong. However it will be a lot easier if you attach your server log from when the message popped up. Without the log most answers will be guesses.
GrimReaper 4928 Posted May 25, 2025 Posted May 25, 2025 @Luke Maybe message there should be rephrased to read "Server's Emby Premiere device limit..." instead of "Your Emby Premiere device limit..." as latter statement is actually incorrect in scenario where a user is connecting to someone else's server. 1
ebr 16357 Posted May 26, 2025 Posted May 26, 2025 Hi. Please contact whomever gave you access to their server.
