twitchstick 7 Posted May 25, 2025 Posted May 25, 2025 Lately my Emby server hangs and is unresponsive. It occurs almost daily and sometimes more than once per day. I never had this happen before and my hardware hasn't changed so I'm not sure the issue. embyserver-63883779031.txt
Luke 42243 Posted May 26, 2025 Posted May 26, 2025 Hi, please try removing these plugins: 2025-05-25 09:50:05.444 Info App: Loading Emby.Plugins.AniList, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Plugins.AniList.dll 2025-05-25 09:50:05.444 Info App: Loading MediaBrowser.Plugins.Anime, Version=1.6.1.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MediaBrowser.Plugins.Anime.dll 2025-05-25 09:50:05.444 Info App: Loading playback_reporting, Version=2.1.0.6, Culture=neutral, PublicKeyToken=null from /config/plugins/playback_reporting.dll 2025-05-25 09:50:05.444 Info App: Loading statistics, Version=3.4.1.1, Culture=neutral, PublicKeyToken=null from /config/plugins/Statistics.dll 2025-05-25 09:50:05.444 Info App: Loading ThemeSongs, Version=1.8.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/themesongs.dll 2025-05-25 09:50:05.444 Info App: Loading Simkl, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Simkl.dll 2025-05-25 09:50:05.444 Info App: Loading Emby.Plugins.AniSearch, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Plugins.AniSearch.dll 2025-05-25 09:50:05.444 Info App: Loading ACdb, Version=2.0.0.1, Culture=neutral, PublicKeyToken=null from /config/plugins/ACdb.dll 2025-05-25 09:50:05.444 Info App: Loading RPDB, Version=1.0.3.2, Culture=neutral, PublicKeyToken=null from /config/plugins/RPDB.dll Then restart the server and see how things compare. Thanks.
Neminem 1623 Posted May 27, 2025 Posted May 27, 2025 Check you credentials in Open subtitle your log is all errors about this. Error searching for subtitles on Open Subtitles *** Error Report *** Version: 4.8.11.0 Command line: /app/emby/system/EmbyServer.dll -programdata /config -ffdetect /app/emby/bin/ffdetect -ffmpeg /app/emby/bin/ffmpeg -ffprobe /app/emby/bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.6.78-Unraid (root@Develop-70) (gcc (GCC) 14.2.0, GNU ld version 2.43.1-slack151) #2 SMP PREEMPT_DYNAMIC Thu Feb 20 13:33:15 PST 2025 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: app/emby/system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /app/emby/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: {"message":"Error, invalid username/password - remember to use your username and not your email to authenticate","status":400} at OpenSubtitles.OpenSubtitleComDownloader.GetResponse(HttpRequestOptions requestOptions, String httpMethod, Int32 allowedRequestFrequencyMs) at OpenSubtitles.OpenSubtitleComDownloader.Login(OpenSubtitleOptions options, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleComDownloader.SearchInternal(SubtitleSearchRequest request, Boolean useFilename, OpenSubtitleOptions options, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleComDownloader.Search(SubtitleSearchRequest request, OpenSubtitleOptions options, CancellationToken cancellationToken) at Emby.Providers.Subtitles.SubtitleManager.SearchSubtitles(SubtitleSearchRequest request, CancellationToken cancellationToken) Source: OpenSubtitles TargetSite: Void MoveNext()
Luke 42243 Posted May 27, 2025 Posted May 27, 2025 That shouldn't be the reason for your issue, but it's probably a good idea to get that cleared up as well.
twitchstick 7 Posted May 28, 2025 Author Posted May 28, 2025 (edited) I uninstalled the plugins and fixed the login info for opensubtitles. Let's see how things go. Edited May 28, 2025 by twitchstick
twitchstick 7 Posted May 29, 2025 Author Posted May 29, 2025 My ember server became unresponsive again. I ran a replace all metadata task for my movie library last night before bed after removing a plugin for my cover art. This morning I tried to check on it and it just spins. The container didn't shut down, but I can't get in. embyserver-63884099732.txt
