Karlos The Jackal 1 Posted May 24, 2025 Posted May 24, 2025 (edited) Hi All, I am having an issue with one particular show, and I can't seem to work out what I am doing wrong. As shown in the first attached screenshot, it's mixing the Specials and Series 1 together, and I can't work out how to have them listed as separate series. I have confirmed with themoviedb that the episodes are labelled correctly and that there is a specials series, though they seem to be labelled in a different order between themoviedb and TVDB, but that shouldn't cause the issue I am experiencing and I have corrected the metadata (I have attached screenshots of this corrected metadata in case this is needed). My file path for this show is: Quote Specials Over the Garden Wall (2014) \ Specials \ Over_the_Garden_Wall_S00E01.mp4 Over the Garden Wall (2014) \ Specials \ Over_the_Garden_Wall_S00E02.mp4 Over the Garden Wall (2014) \ Specials \ Over_the_Garden_Wall_S00E04.mp4 Season 1 Over the Garden Wall (2014) \ Season 1 \ Over_the_Garden_Wall_S01E01.mp4 Over the Garden Wall (2014) \ Season 1 \ Over_the_Garden_Wall_S01E02.mp4 Over the Garden Wall (2014) \ Season 1 \ Over_the_Garden_Wall_S01E03.mp4 Over the Garden Wall (2014) \ Season 1 \ Over_the_Garden_Wall_S01E04.mp4 Over the Garden Wall (2014) \ Season 1 \ Over_the_Garden_Wall_S01E05.mp4 etc What am I missing that could be causing my issue? Edited May 24, 2025 by Karlos The Jackal Adding more detail to title
Abobader 3484 Posted May 24, 2025 Posted May 24, 2025 Hello Karlos The Jackal, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution GrimReaper 4840 Posted May 24, 2025 Solution Posted May 24, 2025 10 minutes ago, Karlos The Jackal said: As shown in the first attached screenshot, it's mixing the Specials and Series 1 together, and I can't work out how to have them listed as separate series Change Preferred series display to "Always show season folders" under user settings>Display tab. 1
Karlos The Jackal 1 Posted May 24, 2025 Author Posted May 24, 2025 Thank you SO much! I can't believe it was that simple! haha 1
