B08853 1 Posted May 23, 2025 Posted May 23, 2025 When you click EDIT on the library, the existing paths are displayed. However, if you click EDIT on a specific path, the 'Library Paths' cannot be modified.
Abobader 3484 Posted May 23, 2025 Posted May 23, 2025 Hello B08853, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42176 Posted May 23, 2025 Posted May 23, 2025 HI ,yes you just need to remove it and then add the new one.
kodho 1 Posted May 23, 2025 Posted May 23, 2025 Bom dia, estou com o mesmo problema, antes de utilizava o Debian e resolvi mudar para Windows, fiz todo o backup porém quando inicio o emby e vou em biblioteca os caminhos do debian ainda aparecem e se clico em EDITAR não consigo modificar! E caso eu clique em remover e adicionar o novo caminho, ele faz uma nova varredura o que acaba modificando várias imagens e dados de series e filmes! Podem ajudar?
Happy2Play 9798 Posted May 23, 2025 Posted May 23, 2025 31 minutes ago, kodho said: Good morning, I have the same problem, before I used Debian and decided to switch to Windows, I did all the backup but when I start emby and go to library the debian paths still appear and if I click on EDIT I can't modify! And if I click on remove and add the new path, it does a new scan which ends up modifying several images and data from series and movies! Can you help? Sorry Emby has no method to move/change already imported paths. It hasn't worked for everyone but the only method is manually editing the database when you do cross platform restores. 1
Luke 42176 Posted May 23, 2025 Posted May 23, 2025 Quote Sorry Emby has no method to move/change already imported paths We plan to in future updates, but we're not there yet. 1
kodho 1 Posted May 23, 2025 Posted May 23, 2025 30 minutes ago, Luke said: Planejamos fazer isso em atualizações futuras, mas ainda não chegamos lá. Obrigado pela ajuda! Fiz alguns testes alterando manualmente e aparentemente deu certo! Muito obrigado!!! 1
B08853 1 Posted May 24, 2025 Author Posted May 24, 2025 Thank you for confirming. The purpose of the edit icon was a bit unclear. While restructuring the server drives, I needed to rename the source folder, which required manually updating the path for each library. It would be a valuable enhancement to enable direct editing of library links and to support adding multiple folder paths at once. 1
