Spaceboy 2573 Posted December 5, 2014 Posted December 5, 2014 I had this also in my adult library. Found that mb3 had created folder.xml's in each media folder alongside the movie.xml. Deleted all the folder.xmls and re ran the library scan and all is now good
Pete90291 0 Posted December 5, 2014 Posted December 5, 2014 I had same issue, i ended up removing library as mixed movies tv and re-adding as "Home Movies". Not the best solution, but it seem to have given me back my movies.. unfortunately now, it reads file name as movie instead of folder name ;(
Luke 42184 Posted December 5, 2014 Posted December 5, 2014 if any of you guys can try the server dev build it has a fix for this. that would be helpful. thanks.
Specter 2 Posted December 5, 2014 Posted December 5, 2014 I grabbed the latest from github and ran the build through visual studios. I was able to see all the files again. However I couldn't play any movies through the web browser. But I assume that's just because I was running the server through debug mode in VS 2013.
Heckler 147 Posted December 9, 2014 Posted December 9, 2014 I tried the android app last night to see if it showed up, and the folder shows up, but each of the sub folders shows as empty. But at elast it hows up, which it doesn't in MC/MB client
ebr 16307 Posted December 9, 2014 Posted December 9, 2014 But at elast it hows up, which it doesn't in MC/MB client Do you have hide empty folders selected in MBC?
