Ausley 1 Posted May 16, 2025 Posted May 16, 2025 I set up the default metadata language as Chinese. After I update all metadata, somehow they are changed to English automatically, even though I locked them up. Does anyone know why? What did I do wrong?
Luke 42176 Posted May 16, 2025 Posted May 16, 2025 HI there, can you please provide a specific example? How to Report a Problem Thanks !
Ausley 1 Posted May 16, 2025 Author Posted May 16, 2025 For instance, I have one BBC TV show, "Happy Valley". I used Identify to search the metadata. The metadata is updated in Chinese (title, overview, etc). Some days later, the metadata was changed to English. I didn't monitor it every day. I don't know when it happened. It only happens on TV shows. The weird thing is that it doesn't happen for all TV shows, only some of them. I put Chinese as the Preferred Metadata Language in every setup I can find (server - Library, App - Metadata Settings), turned off automatically refresh metadata from the internet, and locked those fields or even the whole metadata. It doesn't work.
Luke 42176 Posted May 26, 2025 Posted May 26, 2025 @Ausley Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
VIDE08 2 Posted May 30, 2025 Posted May 30, 2025 Although you have locked the metadata, if it is updated via an external source (and the language in that source is English), the metadata may be overwritten and replaced with the information in the service's default language. snaptube vidmate
