GrimReaper
  • Haha 2
crusher11
How does this differ from what CoverArt does?
GrimReaper
Iconic: You can add custom icons/images (and now tailor their placement if inclined to do so), works on Mixed content-type libraries
CoverArt: sub/audio choices/selections are more granular
Generally, some more scenarios are covered that are not feasible in CoverArt and/or Iconic.
Edited by GrimReaper
  • Like 1
yocker
Assuming CoverArt hasn't changed since last i used it.
EmbyIcons allows for more customizations for where and how the overlays should be shown.
Overlays for TV shows, like showing for example german subtitles if all episodes in a TV show has those subtitles.
Also gives more icons types and is more customizable.
CoverArt is an absolute great plugin and is very close to install and just use.
EmbyIcons requires a bit of tinkering after install as it's settings and possibilities are more comprehensive.
Please note: While EmbyIcons doesn't require a huge CPU or anything like that it still requires a fairly modern CPU if enabling all features.
  • Like 1
MediaIntelNUC
This is awesome..
Why is this not in the Emby catalog of plugin:s?
Edited by MediaIntelNUC
  • Like 1
yocker
2 hours ago, MediaIntelNUC said:
This is awesome..
I basically don't want the responsibility.
If it was a smaller plugin i wouldn't have minded so much.
  • Like 1
MediaIntelNUC
Gotcha!👊
Your plugin your rules brother..
  • Like 3
yocker
New version up on yocksers/EmbyIcons
Added:
  1. Individual corner icon sizing.
  2. Individual corner icon x/y positioning.
  3. Configurable icon spacing.
  4. Background bars for icons, posters will scale to fit.
Changed:
  1. Chasing slightly optimized to improve performance.
Fixed:
  1. Filename rule icons no longer duplicate for each file name hit.
GrimReaper
Added:
Changed:
Fixed:
Is there a difference between that version and this one?
Does it need to be redownloaded?
liuhangbj
新版本已上传至 yocksers/EmbyIcons。
Added:   补充:
    单个角图标尺寸。
    单个角落图标的 x/y 位置。
    可配置图标间距。
    图标的背景条和海报会按比例调整。
Changed:   更改:
    稍微优化了一点以提升性能。
Fixed:   修复:
    每次点击文件名,文件名规则图标不再重复。
Hi,the resolution icon stiil have problem. It always show 720p at the resolution like 1920 *800/1440*1080/1918*1036.
and also to some 4k movie, it don't show any icon if the width is less than 3840 or the heighth is less than 2160.
Just like this
yocker
Same version.
  • Thanks 1
yocker
Just like this
The icon for the first picture is actually correct, it's under 1080p so shows as 720p.
The last one me having made a small mistake where it looked for the wrong icon and since it wasn't there it couldn't display it.
I have changed it to show what ever Emby displays in the title now.
So if Emby shows for example 1080p then the icon will be 1080p.
EmbyIcons.dll
  • Like 1
MediaIntelNUC
You good sir, are AWESOME🫡
  • Haha 1
liuhangbj
第一张图片的图标其实是正确的,分辨率低于 1080p,显示为 720p。
上一次我犯了一个小错误,找错了图标,结果图标不在,所以无法显示。
我现在改成显示 Emby 标题中显示的内容。
所以如果 Emby 显示 1080p,那么图标也会是 1080p。
EmbyIcons.dll 3.99 MB · 0 下载量
Ja, this example is not so good. But I think it still shoul be thought as 1080p, although its width is less than 1920, and heighth is less than 1080. and emby also recognize it as 1080p.
there is another example which is more typical.
yocker
Looks like you have two versions of that movie, the plugin most likely shows the icon for the other one.
The plugin only shows what Emby says in the title so if there are two versions of the movie it will just take the first it sees.
I can look into adding multi version support.
Edited by yocker
liuhangbj
看起来你有两个版本的那个电影,插件很可能显示的是另一个版本的图标。
插件只显示 Emby 标题中的内容,所以如果有两个版本的电影,它只会用第一个看到的版本。
我可以考虑添加多版本支持。
No, I have just one version.
liuhangbj
我可以考虑添加多版本支持。
Another movie, which resolution is 1920*1040, it also show 720p.
It seems that the plugin recognize all the movie which heighth is less than 1080 as 720p.
liuhangbj
另一部电影分辨率是 1920*1040,也显示 720p。
看起来插件把所有高度低于 1080 的电影都识别为 720p。
And,  on this movie, why the audio codec icon, which should show DTS-HD or DTS, did't show on the poster?
yocker
Strange, never seen Emby show a selector when only one version is available.
Edited by yocker
  • Agree 1
yocker
I never added an embedded icon to the plugin as i'm no artist and the built in icons are meant more as examples and for getting the plugin going.
Users are meant to supply their own icons.
I have added one in this version for DTS-MA so they will shown up.
I also made a small change to the resolution detection so it might work better in your situation.
After having installed this, remember to change one of the icon positions so the plugin redraws the icons.
EmbyIcons.dll
Edited by yocker
  • 2 weeks later...
MediaIntelNUC
Hi Yocker!
I was wondering if there would be any options regarding the black bars setting in different poster wievs?
When i have "Primary" as settings the bar works beautifully, but my girlfriend likes her library as "Landscape" and then the black bar is a bit off,
Is there any way for me to correct it with separate settings on a user basis or do i rize it enough in the setting to cover icons in both combined with changing icon size to smaller to find some middle ground?
Pic:s attached.
Thanx!
Info added
yocker
6 hours ago, MediaIntelNUC said:
Hi Yocker!
Pic:s attached.
Thanx!
I will fix the scaling.
Problem is that i forgot both horizontal and vertical are things that exist in this world. ;)
  • Like 1
MediaIntelNUC
@yocker
Sweet!
I happens to the best of us😉
yocker
22 hours ago, MediaIntelNUC said:
@yocker
Sweet!
This should fix the issue.
EmbyIcons.dll
Edited by yocker
  • Thanks 2
MediaIntelNUC
Worked great!
Thanx!
N.
  • Like 1
  • Agree 1
