yocker
6 minutes ago, GrimReaper said:
Yes, that works.
This doesn't:
That is what cannot be achieved/does not produce Status icon: no Subtitle Language, no Original Language, yes Status.
Ahh yes, me being an idiot (as always).
Uploaded the wrong version.
Nice find and many thanks! :)
Edited by yocker
  • Haha 1
GrimReaper
Nah, many thanks to you for all these wonderful plugins. 🍻
Edited by GrimReaper
  • Like 1
yocker
Just now, GrimReaper said:
Nah, many thatks to you for all these wonderful plugins. 🍻
I have uploaded the right one, if that doesn't fix it then there is something wrong deep down i need to fix.
  • Thanks 1
GrimReaper
Working good, well done. Thanks. 👍
  • Thanks 1
GrimReaper
Guess this setting was removed through all the plugin iterations - or I'm simply incapable of finding it?
yocker
It caused havoc with the icon overflow.
Can look into it again if it's a needed feature. :)
GrimReaper
Wouldn't bother asking if it weren't? 😉
But seriously, if it's causing havoc or giving you too much of a headache - forget it, work on something that'd benefit the majority, I'll manage.
  • Like 1
WJCuffe
Here is an icon for the Popcorn-O-Meter status of Hot.  Fresh is used by the Tomato-meter.
  • Like 1
GrimReaper
Seems like series_running.png and series_ended.png are not checked for in Custom folder? Nor are they reported in Icon Manager?
yocker
User custom folder uses series.running.png and series.ended.png.
Not series_
  • Thanks 1
yocker
@GrimReaper
I have added a setting for controlling the icon spacing that was hardcoded before.
This is the best i can do for now.
Controlling the x and y for icons will be complicated as the plugin is using % of poster and icons to make them actually fit properly on the posters.
Hopefully this will at least forfil your request just a little. :)
It will be part of the next release.
  • Like 1
  • Thanks 1
GrimReaper
Thanks, but if it doesn't affect initial/first icon placement (in respect to poster edges) but only spacing between them - not much. Still, thanks for the effort.
  • Like 1
yocker
I'm working on seeing if I can fix it ATM. Together with some other enhancements like the bars people have requested.
Can't promise anything though.
  • Thanks 1
liuhangbj
我正在努力看看能不能修好它。再加上一些其他增强,比如大家要求的酒吧。
不过不能保证。
a new problem appears,
If a serie have 10 episodes, there will be 10 icons displayed on the series poster, which is suited with the filename rule to one episode, like this.
  • Thanks 1
yocker
Wops, guess i added it to the series aggregation wrong.
Fixed in the next version (soon).
Thanks for reporting it!
  • Haha 1
yocker
I've added settings for some other wise hardcoded values to icon placements.
I also fixed the filename rule bug that put an icon in for every file name hit.
Pictures speak louder than words.
@GrimReaperThe last one there might be of interest to you, again it's the best i can do as everything is % based so hard to make everything move independently.
WARNING!! WARNING!! WARNING!! USE AT YOUR OWN RISK!!
This is a beta and should only be used on a test server as bugs might have been overlooked or new once have snugged in.
Keep in mind that enabling everything at once might be CPU intensive for smaller CPU's so keep an eye on your CPU usage if using small and/old CPUs!
Testing has been done on a system with Ryzen 3900x with no noticeable slow down, granted that isn't a small CPU.
A thank you to @Neminemfor testing the caching optimizations i did so i could add the extra features and reminding me that a save button would be needed. :D
A thank you to all for the suggestions as well! Don't be afraid to come with suggestions even though i might be more and more inclined to reject them as the plugin gets bigger and bigger.
EmbyIcons.dll
  • Like 2
GrimReaper
Those are all great additions. Well done.
GrimReaper
Thanks for implementing that - unfortunately, not really useful (in my scenario) as icons move diagonally according Edge Padding value - IMHO they should move based on selected layout: for vertical layout, padding should be counted from upper/lower poster edge and vice-versa, for horizontal layout it should be counted from left/right poster edge. Or split that setting into vertical & horizontal padding value, if feasible. Thanks.
yocker
I can split it up to independant horizontal and vertical controls somewhat easy.
Each corner separately will be harder, will see what i can do.
Edited by yocker
  • Like 1
  • Thanks 1
yocker
@GrimReaperI cracked it i think.
Hot from the oven.
EmbyIcons.dll
Edited by yocker
  • Like 2
yocker
Oh, yes, beautiful. Great work, as always. Kudos. 👍
No problem, gotta keep the local mod happy. :)
  • Like 1
  • Haha 2
Neminem
Did you just call the Grim Reaper a bad dog "mod" 😂🤣
  • Haha 2
yocker
How dare you! Hes an awesome, highly intelligent, good looking, strong and better than any one else guy!!
Please don't ban me!! ;)
  • Haha 2
