yocker 1358 Posted February 17 Author Posted February 17 5 hours ago, liuhangbj said: I have tried the version 5.50.2, 5.50.0, 5.43.3. All of them don't work embyserver.txt 1.11 MB · 1 download I have gotten very sick so can't look at it right now. I promise i will look at it as soon as i'm better.
liuhangbj 3 Posted February 18 Posted February 18 8 hours ago, yocker said: I have gotten very sick so can't look at it right now. 我病得很重,现在不能看。 I promise i will look at it as soon as i'm better. 我保证我一好转就会去看看。 Just to take care of yourself,this problem is not a big deal 1
yocker 1358 Posted February 18 Author Posted February 18 5 hours ago, liuhangbj said: Just to take care of yourself,this problem is not a big deal Thank you. I was bored lying in my bed feeling sorry for my self so took a short look at the log. I can see Emby for Mac still uses .net 6 and Embyicons was updated to use .net 8 some time ago. I made a small edit in the plugin to make it .net 6 compatible, with the change it might run but i have no Apple Mac to test it. Please report back if it starts as it should. EmbyIcons.dll
liuhangbj 3 Posted February 18 Posted February 18 4 hours ago, yocker said: Thank you. I was bored lying in my bed feeling sorry for my self so took a short look at the log. I can see Emby for Mac still uses .net 6 and Embyicons was updated to use .net 8 some time ago. I made a small edit in the plugin to make it .net 6 compatible, with the change it might run but i have no Apple Mac to test it. Please report back if it starts as it should. EmbyIcons.dll 3.93 MB · 0 downloads EmbyIcons.dll 3.93 MB · 0 下载量 OK, I will try. THank you
liuhangbj 3 Posted February 18 Posted February 18 6 hours ago, yocker said: Thank you. 谢谢你。 I was bored lying in my bed feeling sorry for my self so took a short look at the log. 我躺在床上无聊,自怜自怜,于是短暂地看了看那根木头。 I can see Emby for Mac still uses .net 6 and Embyicons was updated to use .net 8 some time ago. 我看到 Emby for Mac 仍然使用 .net 6,而 Embyicons 之前更新为使用 .net 8。 I made a small edit in the plugin to make it .net 6 compatible, with the change it might run but i have no Apple Mac to test it. 我在插件里做了小修改,使其兼容.NET 6,改动后可能会运行,但我没有 Apple Mac 可以测试。 Please report back if it starts as it should. 如果开始正常,请回来反馈。 EmbyIcons.dll 3.93 MB · 1 download EmbyIcons.dll 3.93 MB · 1 下载 After fast use, it's a perfect resolve for me, especially it has filename rule, it's a simple way for me to show the chinese subtitle icon, because I rename the movie filename including "[ZH]" if it has a chinese subtitle include. Just two little advice: 1. some sesolution display is not as same as emby do. for exmple, the resolution is 1306*1080, but the icon shows 720p 2. DoVi P8 can use a DV+HDR icon, instead of just DV, the only DV icon should be used for DoVi P5. and if there is no HDR format, you can use a SDR icon. That's all. Thank you again, It's really a perfect plugin. I think I don't need KOMETA now 1
yocker 1358 Posted February 18 Author Posted February 18 41 minutes ago, liuhangbj said: After fast use, it's a perfect resolve for me, especially it has filename rule, it's a simple way for me to show the chinese subtitle icon, because I rename the movie filename including "[ZH]" if it has a chinese subtitle include. Just two little advice: 1. some sesolution display is not as same as emby do. for exmple, the resolution is 1306*1080, but the icon shows 720p 2. DoVi P8 can use a DV+HDR icon, instead of just DV, the only DV icon should be used for DoVi P5. and if there is no HDR format, you can use a SDR icon. That's all. Thank you again, It's really a perfect plugin. I think I don't need KOMETA now Good to hear it worked out for you. The resolution is a problem i already fixed once, guess i have reintroduced the problem again later. Will look at it when i have time and feeling better. The Dolby Vision thing is done on purpose. The hierarchy is from lowest to highest HDR -> HDR10 (if file name has HDR10plus in it since Emby does not support showing that information yet) -> Dolby Vision. It simply shows the highest color format. I see there is a link in one of the pictures, best to remove that from here before it causes problems.
liuhangbj 3 Posted February 18 Posted February 18 4 minutes ago, yocker said: Good to hear it worked out for you. 很高兴听到你成功了。 The resolution is a problem i already fixed once, guess i have reintroduced the problem again later. 解决问题我之前已经解决过一次,估计我之后又重新引入了这个问题。 Will look at it when i have time and feeling better. 等我有时间、感觉好些了会去看看。 The Dolby Vision thing is done on purpose. 杜比视界的设定是故意为之。 The hierarchy is from lowest to highest HDR -> HDR10 (if file name has HDR10plus in it since Emby does not support showing that information yet) -> Dolby Vision. 层级顺序是从最低到高的 HDR-> HDR10(如果文件名里有 HDR10plus,因为 Emby 还不支持显示该信息)->Dolby Vision。 It simply shows the highest color format. 它只是显示最高色彩格式。 I see there is a link in one of the pictures, best to remove that from here before it causes problems. 我看到其中一张图片里有个链接,最好先把它从这里移除,免得引发问题。 another little problem, the rating icon displayed on me server is a TMDB icon, But I want use IMDB icon, how can I do this?
Neminem 1590 Posted February 18 Posted February 18 2 hours ago, liuhangbj said: another little problem, the rating icon displayed on me server is a TMDB icon, But I want use IMDB icon, how can I do this? Replace the Icon / image
liuhangbj 3 Posted February 19 Posted February 19 10 hours ago, Neminem said: Replace the Icon / image 替换图标/图片 ja, already done
liuhangbj 3 Posted February 19 Posted February 19 13 hours ago, yocker said: Good to hear it worked out for you. The resolution is a problem i already fixed once, guess i have reintroduced the problem again later. Will look at it when i have time and feeling better. The Dolby Vision thing is done on purpose. The hierarchy is from lowest to highest HDR -> HDR10 (if file name has HDR10plus in it since Emby does not support showing that information yet) -> Dolby Vision. It simply shows the highest color format. I see there is a link in one of the pictures, best to remove that from here before it causes problems. Only one more advice Make the filename rule can be used in Series/Episode. so that you can make subtitle/network icons displayed on Series posters. And can I reorder every filename rule by using Priority
yocker 1358 Posted February 19 Author Posted February 19 10 hours ago, liuhangbj said: Only one more advice Make the filename rule can be used in Series/Episode. so that you can make subtitle/network icons displayed on Series posters. And can I reorder every filename rule by using Priority Not a bad idea, i will look into it! Thanks!
yocker 1358 Posted February 22 Author Posted February 22 On 2/19/2026 at 4:55 AM, liuhangbj said: Only one more advice Make the filename rule can be used in Series/Episode. so that you can make subtitle/network icons displayed on Series posters. And can I reorder every filename rule by using Priority I have fixed the resolution problem and added filename rules for Shows and episodes. Please report if you find any problems. EmbyIcons.dll
GrimReaper 4828 Posted February 22 Posted February 22 Could you add an icon for TV show Status (Continuing/Ended)? Thanks.
liuhangbj 3 Posted February 22 Posted February 22 4 hours ago, yocker said: I have fixed the resolution problem and added filename rules for Shows and episodes. 我已经修复了分辨率问题,并为节目和剧集添加了文件名规则。 Please report if you find any problems. 如果发现任何问题,请报告。 EmbyIcons.dll 3.93 MB · 2 downloads EmbyIcons.dll 3.93 MB · 2 次下载 I have tried the new version, the filename rules work fine with series and seasons, but seems to have problem with episodes. My chinese subtitle icon is displayed on Series and seasons poster, but not shown on episode fanarts
yocker 1358 Posted February 22 Author Posted February 22 6 hours ago, GrimReaper said: Could you add an icon for TV show Status (Continuing/Ended)? Thanks. Will see what i can do about it. 5 hours ago, liuhangbj said: I have tried the new version, the filename rules work fine with series and seasons, but seems to have problem with episodes. My chinese subtitle icon is displayed on Series and seasons poster, but not shown on episode fanarts Strange, looking at it now. 1
yocker 1358 Posted February 23 Author Posted February 23 19 hours ago, GrimReaper said: Could you add an icon for TV show Status (Continuing/Ended)? Thanks. I have a request for you too, show me some icons that would be fitting for this feature.
yocker 1358 Posted February 23 Author Posted February 23 (edited) 19 hours ago, liuhangbj said: I have tried the new version, the filename rules work fine with series and seasons, but seems to have problem with episodes. My chinese subtitle icon is displayed on Series and seasons poster, but not shown on episode fanarts This one should fix it. Please report back if there are any problems. EmbyIcons.dll Edited February 23 by yocker
GrimReaper 4828 Posted February 23 Posted February 23 (edited) 5 hours ago, yocker said: I have a request for you too, show me some icons that would be fitting for this feature. LOL never thought about it, but here are some examples that might be fitting? Continuing: Ended: Edited February 23 by GrimReaper 1 1
yocker 1358 Posted February 23 Author Posted February 23 3 hours ago, GrimReaper said: LOL never thought about it, but here are some examples that might be fitting? Continuing: Ended: I'm thinking of making it only show an icon on ended and not when a show is still running. I can't decide so what do you think? Does it only need the one icon or for both?
GrimReaper 4828 Posted February 23 Posted February 23 Personally, I'd go with both as I like uniformity - so all posters would have an icon, instead of have-have-doesn't have-have. 2
yocker 1358 Posted February 23 Author Posted February 23 7 minutes ago, GrimReaper said: Personally, I'd go with both as I like uniformity - so all posters would have an icon, instead of have-have-doesn't have-have. Then that is how it will be. Nice to have other people do a little work too. 2
yocker 1358 Posted February 23 Author Posted February 23 29 minutes ago, GrimReaper said: Personally, I'd go with both as I like uniformity - so all posters would have an icon, instead of have-have-doesn't have-have. Quick preview, testing the icons, the feature is not done/started yet. Will start working on it tonight. 1
GrimReaper 4828 Posted February 23 Posted February 23 23 minutes ago, yocker said: Quick preview, testing the icons, the feature is not done/started yet. Will start working on it tonight. v2 to better go with square theme? 2
yocker 1358 Posted February 23 Author Posted February 23 27 minutes ago, GrimReaper said: v2 to better go with square theme?
liuhangbj 3 Posted February 24 Posted February 24 8 hours ago, GrimReaper said: Personally, I'd go with both as I like uniformity - so all posters would have an icon, instead of have-have-doesn't have-have. 就我个人而言,我会两种都选,因为我喜欢统一性——这样所有海报都会有一个图标,而不是有就没就没。 The same habbit. I really want a SDR icon, when there are no DV/HDR10/HDR format in the video files. By the way, are you planning to working on reorder the filename rules by priority? Even can display on the different position of the poster? I want the source icons like bluray/WEB-DL/REMUX can be separated with edition icons like CC/MoC/DC/TC.
