CarneAsada 12 Posted September 16, 2025 Posted September 16, 2025 Hello, Attempting to install on Ubuntu Linux beta: emby-server-deb_4.9.1.31_amd64.deb After installing latest .DLL file and restarting, it crashes EMS.
yocker 1423 Posted September 16, 2025 Author Posted September 16, 2025 2 hours ago, CarneAsada said: Hello, Attempting to install on Ubuntu Linux beta: emby-server-deb_4.9.1.31_amd64.deb After installing latest .DLL file and restarting, it crashes EMS. I will look into it. It's using the dependencies for the stable version, maybe they are not compatible with the beta anymore. 1
yocker 1423 Posted September 16, 2025 Author Posted September 16, 2025 3 hours ago, CarneAsada said: Hello, Attempting to install on Ubuntu Linux beta: emby-server-deb_4.9.1.31_amd64.deb After installing latest .DLL file and restarting, it crashes EMS. I just tested the plugin with the beta installed in Linux. The plugin works as it should with no errors on my end. Can i get you to provide me a log from Emby with the crash?
akacharos 34 Posted October 1, 2025 Posted October 1, 2025 I confirm issue with EmbyIcons and 4.9.1.80 I had the latest dll installed while in latest 4.8 and Emby autoinstall the final version of 4.9 ( 4.9.1.80). Upon reboot EMS crashed and it took me a while to figure out it was EmbyIcons plugin. Once I removed the dll from the plugins folder and restarted EMS, it loads fine.
yocker 1423 Posted October 1, 2025 Author Posted October 1, 2025 40 minutes ago, akacharos said: I confirm issue with EmbyIcons and 4.9.1.80 I had the latest dll installed while in latest 4.8 and Emby autoinstall the final version of 4.9 ( 4.9.1.80). Upon reboot EMS crashed and it took me a while to figure out it was EmbyIcons plugin. Once I removed the dll from the plugins folder and restarted EMS, it loads fine. Strange, it should work with the new version. As soon as i get the new version to test with i will try and update the dependencies the plugin has and see if that help.
yocker 1423 Posted October 1, 2025 Author Posted October 1, 2025 48 minutes ago, akacharos said: I confirm issue with EmbyIcons and 4.9.1.80 I had the latest dll installed while in latest 4.8 and Emby autoinstall the final version of 4.9 ( 4.9.1.80). Upon reboot EMS crashed and it took me a while to figure out it was EmbyIcons plugin. Once I removed the dll from the plugins folder and restarted EMS, it loads fine. Just noticed my Emby test server had already updated. Embyicons seems to run fine on it though. Can i get you to try and reset the browser cache (ctrl-shift-f5) and see if that help? In the mean time i will test with the new dependencies. 1
akacharos 34 Posted October 1, 2025 Posted October 1, 2025 (edited) Sadly is not client side issue, so cache won't help. Check my thread earlier today. The tricky part is that EMS crashes without any log output to give a hint. What I can try to do is to remove any existing configuration from EmbyIcons and start from scratch. Currently, if I just add the dll, crash occurs. Apart from config files in plugins/configurations , are there any other files being generated with the installation of the plugin? Edited October 1, 2025 by akacharos
yocker 1423 Posted October 1, 2025 Author Posted October 1, 2025 8 minutes ago, akacharos said: Sadly is not client side issue, so cache won't help. Check my thread earlier today. The tricky part is that EMS crashes without any log output to give a hint. What I can try to do is to remove any existing configuration from EmbyIcons and start from scratch. Currently, if I just add the dll, crash occurs. Apart from config files in plugins/configurations , are there any other files being generated with the installation of the plugin? The settings file is the only one.
yocker 1423 Posted October 1, 2025 Author Posted October 1, 2025 32 minutes ago, akacharos said: Sadly is not client side issue, so cache won't help. Check my thread earlier today. The tricky part is that EMS crashes without any log output to give a hint. What I can try to do is to remove any existing configuration from EmbyIcons and start from scratch. Currently, if I just add the dll, crash occurs. Apart from config files in plugins/configurations , are there any other files being generated with the installation of the plugin? Sadly hard to me to troubleshoot this as it works on all serveres i install it on. You can try and see if this version fixes it though as it's updated to use the latest Emby server .dlls. EmbyIcons.dll
yocker 1423 Posted October 2, 2025 Author Posted October 2, 2025 I fixed some (very) edge case problems that might happen with the plugin. You can see if that fixes it. EmbyIcons.dll
akacharos 34 Posted October 2, 2025 Posted October 2, 2025 (edited) the bad news is that the issue persists even with the latest version. the good news is that this time I managed to get debug logs. Not sure what that means: Debug Plugin: [EmbyIcons] Populating library path cache using Trie. Should I delete the whole Emby cache? deleting cache didn't help embyserver-deb-anon.txt Edited October 2, 2025 by akacharos
Doppellhelix 17 Posted October 2, 2025 Posted October 2, 2025 Same Problem after Updating to 4.9.1.80 Latest EmbyIcons.dll does not solve the Problem.
yocker 1423 Posted October 2, 2025 Author Posted October 2, 2025 Try this one, it should fix the problem. EmbyIcons.dll 3
ISeeTWizard 29 Posted October 2, 2025 Posted October 2, 2025 17 minutes ago, Doppellhelix said: Same Problem after Updating to 4.9.1.80 Latest EmbyIcons.dll does not solve the Problem. Was meinst du nach einiger Zeit Habe jetzt meinen Server geupdated und habe noch keine Probleme unter Ubuntu - aber wenn es ne Stunde dauert bis er crashed dann dauert es noch
Doppellhelix 17 Posted October 2, 2025 Posted October 2, 2025 47 minutes ago, yocker said: Try this one, it should fix the problem. Yes, that works. Thank you for this 1
yocker 1423 Posted October 2, 2025 Author Posted October 2, 2025 1 minute ago, Doppellhelix said: Yes, that works. Thank you for this Good to hear! And thank you to
sh0rty 728 Posted October 2, 2025 Posted October 2, 2025 Hell yeah! Thanks @yockerDid not know what to to without the plugin 1
yocker 1423 Posted October 2, 2025 Author Posted October 2, 2025 Now i just need to optimize the movies look ups to speed it up a bit and it should be running good for a while. Please note: It's nothing that will be a big speed increase but work taking. 3 hours ago, akacharos said: the bad news is that the issue persists even with the latest version. the good news is that this time I managed to get debug logs. Not sure what that means: Debug Plugin: [EmbyIcons] Populating library path cache using Trie. Should I delete the whole Emby cache? deleting cache didn't help embyserver-deb-anon.txt 144.84 kB · 3 downloads Just writing you so you get a notification in case you havn't seen the new version.
yocker 1423 Posted October 2, 2025 Author Posted October 2, 2025 New version now up on yocksers/EmbyIcons Github
Neminem 1625 Posted October 2, 2025 Posted October 2, 2025 @yockerI will test v5.38.7 when I update my test emby server. I want to see what happens with docker version of emby. Sadly the docker has still not been build. 1
yocker 1423 Posted October 2, 2025 Author Posted October 2, 2025 21 minutes ago, Neminem said: @yockerI will test v5.38.7 when I update my test emby server. I want to see what happens with docker version of emby. Sadly the docker has still not been build. It should work, it was a minor thing that was wrong with it. Though ofc.. You should never say never! 1
Neminem 1625 Posted October 2, 2025 Posted October 2, 2025 1 minute ago, yocker said: It should work, it was a minor thing that was wrong with it. Though ofc.. You should never say never! When updating servers I usually remove all none standart plugins I do not want to break Emby by a fluke plugin, especially with major release's.
yocker 1423 Posted October 2, 2025 Author Posted October 2, 2025 2 minutes ago, Neminem said: When updating servers I usually remove all none standart plugins I do not want to break Emby by a fluke plugin, especially with major release's. Agree, on my main server i only run EmbyIcons and only real custom setting in Emby is a auto quality fix but even that gets removed when updating. Emby has been for me one of the least troublesome programs i have ever used, so usually no problems.. Knock on wood.. 1
Neminem 1625 Posted October 3, 2025 Posted October 3, 2025 @yockerI just upgraded my test server with this plugin enabled, v.5.38.7.0 No issues found, running docker. 1
