Neminem 1625 Posted August 14, 2025 Posted August 14, 2025 When switching from TV to front page how is that ? With plugin installed. TV Show and 3 more pages - Personal - Microsoft Edge 2025-08-14 16-09-11.mp4 Witnout NormalTest and 3 more pages - Personal - Microsoft Edge 2025-08-14 16-14-50.mp4
Neminem 1625 Posted August 14, 2025 Posted August 14, 2025 Where should the Ignore folder be in Emby termes.
yocker 1423 Posted August 14, 2025 Author Posted August 14, 2025 (edited) This is my last try at a quick fix, if this doesn't work it then i will go through every single little byte of code to see what is wrong. Also try and delete the configuration file in plugins/configuration. @Neminemno where, if the plugin is set to not work with a library it will ignore that library. EmbyIcons.dll Edited August 14, 2025 by yocker
Neminem 1625 Posted August 14, 2025 Posted August 14, 2025 (edited) Ok because I could not find it Will test the new version and report back later. Edited August 14, 2025 by Neminem 1
Neminem 1625 Posted August 14, 2025 Posted August 14, 2025 (edited) Can this setting have factor. Since my storage is on my main unRaid server ? Could it be a Emby Cache issue ? My network is 2.5gb between them. Edited August 14, 2025 by Neminem
yocker 1423 Posted August 14, 2025 Author Posted August 14, 2025 Hmm.. Never actually thought about that setting. Yes it's possible.
Neminem 1625 Posted August 14, 2025 Posted August 14, 2025 (edited) Hmm just for the fun of it I will NUKE my test server Import my tv shows and movies only. Then en able TV shows. And report back. All my media has images and nfo side by side to media files, for faster recovery Well and of cause NOT enable that Edited August 14, 2025 by Neminem 1
yocker 1423 Posted August 14, 2025 Author Posted August 14, 2025 9 minutes ago, Neminem said: Hmm just for the fun of it I will NUKE my test server Import my tv shows and movies only. Then en able TV shows. And report back. All my media has images and nfo side by side to media files, for faster recovery Well and of cause NOT enable that Haha love that dedication!! 1
Neminem 1625 Posted August 14, 2025 Posted August 14, 2025 Well its only a appdate store for that docker, delete rebuild
sh0rty 728 Posted August 14, 2025 Posted August 14, 2025 (edited) 3 hours ago, yocker said: This is my last try at a quick fix, if this doesn't work it then i will go through every single little byte of code to see what is wrong. Also try and delete the configuration file in plugins/configuration. @Neminemno where, if the plugin is set to not work with a library it will ignore that library. EmbyIcons.dll 3.38 MB · 1 download For me, this version brings little improvement for the startpage after image cache is fully built up, tried it with wiping the xml before update. But it seems the images load faster now when rebuilding cache during scrolling through the library. Edit: Strange that the continue watching images are not affected and load instantly, even if they are also touched by the plugin (at least on my system). Edited August 14, 2025 by sh0rty
yocker 1423 Posted August 15, 2025 Author Posted August 15, 2025 For those with the problem try this version. I'm still not done but for now this will at least help a lot. EmbyIcons.dll 1 1 1
Neminem 1625 Posted August 15, 2025 Posted August 15, 2025 Is that the same as the one you send me yesterday and the one I tested this morning ?
yocker 1423 Posted August 15, 2025 Author Posted August 15, 2025 (edited) 18 minutes ago, Neminem said: Is that the same as the one you send me yesterday and the one I tested this morning ? Slightly different. In the first one i had temporally disabled the profile system. On the other i had fixed unnecessary banner and thumb drawing the plugin might have done. Edited August 15, 2025 by yocker 1
IAmHugh 64 Posted August 15, 2025 Posted August 15, 2025 @yockerlooks like for some odd reason your plugin is now working. I just went into Emby to make sure a new movie and a couple of TV episodes from last night got listed and I noticed the below. I'm assuming the small banners at the top of the image posters are from your plugin.
Neminem 1625 Posted August 15, 2025 Posted August 15, 2025 @CummingCowGirlIt not from this plugin, I think those are from Cover-art.
yocker 1423 Posted August 15, 2025 Author Posted August 15, 2025 53 minutes ago, CummingCowGirl said: @yockerlooks like for some odd reason your plugin is now working. I just went into Emby to make sure a new movie and a couple of TV episodes from last night got listed and I noticed the below. I'm assuming the small banners at the top of the image posters are from your plugin. Yes, i think i wrote you about it, I made it have built in icons precisely so people in your situation would be able to get it to work. No, my plugin does not show banners like that. 1
WJCuffe 15 Posted August 15, 2025 Posted August 15, 2025 Okay, found something really minor in v3.51.9... Cleared cache, and after running the Icon Manager, it shows Custom Tags that are needed. For example, "tag.babylon 5.png". According to the Readme section, any spaces in Custom Tag names need to be replaced with dashes? Because of that assumption, I do have an icon "tag.babylon-5.png". That icon is showing up on on movie/series posters. However, the Icon Manager lists the "tag.babylon-5.png" icon as being unused. Seems like the plugin is using the hyphenated name Custom Tags, just not acknowledging that the icon exists and therefore list them again as "needed". It's nothing that breaks functionality, but someone could get confused and double up trying to solve the discrepancy... 1
Neminem 1625 Posted August 15, 2025 Posted August 15, 2025 You mean 3.31.9.0 right ? Releases · yocksers/EmbyIcons
WJCuffe 15 Posted August 15, 2025 Posted August 15, 2025 (edited) Yep, damn typos! Err, no, 5.31.9... Now we're both doing it. Edited August 15, 2025 by WJCuffe 1
yocker 1423 Posted August 15, 2025 Author Posted August 15, 2025 If the fix doesn't work I will go back to the last good one and add the new features. I'm really sorry about it as it should just f.ing work. Thank you all for the testing!! 2
IAmHugh 64 Posted August 15, 2025 Posted August 15, 2025 7 hours ago, yocker said: Yes, i think i wrote you about it, I made it have built in icons precisely so people in your situation would be able to get it to work. No, my plugin does not show banners like that. Ok so you're confusing me. Yes they are yours but no they aren't? I mean either way it looks good.
yocker 1423 Posted August 15, 2025 Author Posted August 15, 2025 5 minutes ago, CummingCowGirl said: Ok so you're confusing me. Yes they are yours but no they aren't? I mean either way it looks good. Sorry I will explain tomorrow when I'm sober again. I'm at a metal concert right now. But if you understand nu drunken talk my plugin does not make does "banners". I only added built in icons so it would work for people in your situation. 1
IAmHugh 64 Posted August 15, 2025 Posted August 15, 2025 OK so those banners are from something else. I'll have to checkout you you mean about built in icons. Talk to you tomorrow. Enjoy your concert. 1
keitaro26 22 Posted August 15, 2025 Posted August 15, 2025 (edited) 31 minutes ago, CummingCowGirl said: OK so those banners are from something else. I'll have to checkout you you mean about built in icons. Talk to you tomorrow. Enjoy your concert. The banners look like they are from a plugin called CoverArt. EmbyIcons only does the little icons for languages, codecs, etc., no banners. Fallback icons were added into the plugin for people who can't grant permissions to use custom icon, like on Arch, so that the plugin could still render even without custom icons. From your screenshots, I don't see any icon that are being rendered by EmbyIcons. Edited August 15, 2025 by keitaro26
