Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 (edited) 4 hours ago, keitaro26 said: Is there any way to apply the icon to the series posters on TV shows instead of the episodes themselves? I would think this would be problematic. Since the tv show poster does not contain audio or subs it self. But episodes does. If you have 5 episodes with audio eng + fra, subs eng + fra. And then another 5 episodes with audio fra, subs eng. What would be showen on the TV show poster, when having to choose between that. Edited May 18, 2025 by Neminem
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 5 hours ago, keitaro26 said: Is there any way to apply the icon to the series posters on TV shows instead of the episodes themselves? I did sort of get something like that to work. Sadly it would work in the way that if any of the episodes, as in just one, had a subtitle or audio language the icon would get shown on the TV poster. Never got it to only do it if only all episodes had it.
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 1 hour ago, Neminem said: If you have 5 episodes with audio eng + fra, subs eng + fra. And then another 5 episodes with audio fra, subs eng. What would be showen on the TV show poster, when having to choose between that. Precisely, i could never get some logic to work with if only all episodes had it.
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 (edited) 6 hours ago, keitaro26 said: Is there any way to apply the icon to the series posters on TV shows instead of the episodes themselves? @Neminem Speak of the devil.. Try this one please. Tell me if there are any problems. It will need a refresh of the meta data on the show before an icon is shown, also remember to enable the setting for it. Edit: Forgot to say, it will only show an icon if ALL episodes have audio or subtitles of a language. EmbyIcons.dll Edited May 18, 2025 by yocker 1
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 If it has no problems i will be a beer poorer.. Please find faults!
Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 @yockerjust testing this on beta and release. 1) I can't seam to get subs to work in this version, I have not been testing this from v.1.17 so not sure when it stopped adding Icon about subs. I only ues .srt subs ( da.srt and en.srt ) 2) Logs are no longer being generated, it was working in a previous version so I guess its not a permission issue. Just checked permissions again, should be good. But it does show audio language
Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 (edited) Just to add to this. I'm not expecting sub icons on poster, in this case. I have extras without .srt files. Edited May 18, 2025 by Neminem
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 Logs not working is because it's just a small test version with the code from a friend. Subtitles should work though. Maybe I messed up again, try putting the .srt in q quotes.
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 (edited) Found the problem, non-embedded subtitles are no longer checked Edited May 18, 2025 by yocker
Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 10 minutes ago, yocker said: Found the problem, embedded subtitles are no longer checked I don't follow ? I don't use embedded subs, all my subs single file besides media
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 5 minutes ago, Neminem said: I don't follow ? I don't use embedded subs, all my subs single file besides media Yeah sorry, was my phone not liking me writing non before the other text 1
Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 Disregard my above post, I clearly misread your commend Or was too fast to reply, I can see you edited you commend
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 (edited) That was a pain.. Everything should work now. Edit: Also extremely embarrassing.. Seems i broke a lot of stuff 2 versions back without noticing. EmbyIcons.dll Edited May 18, 2025 by yocker
Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 Looks better, its taking in subs again, just waiting for it to finish Logs are also being generated again
Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 All done all normal episodes are showing language and subs flags But as suspected show poster is only showing language flag. I have this other folder, with 1 video file without srt files
Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 (edited) Hmm I have created some dummy srt files, for that 1 file without srt files. And the episode is now showing language and subs on thumb. Ohh yes I'm sure all normal episodes + specials have srt files, checked that too. But the Tv show poster did not change to show subs also, it only shows language. Will do a complete rescan of library + metadata with replace pictures, later If its because I'm too impatient Edited May 18, 2025 by Neminem
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 I'm an idiot, TV show posters doesn't look for external subtitles still.. Fixing! 1
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 12 minutes ago, Neminem said: Hmm I have created some dummy srt files, for that 1 file without srt files. And the episode is now showing language and subs on thumb. But the Tv show poster did not change to show subs also, it only shows language. Will do a complete rescan of library + metadata with replace pictures, later If its because I'm too impatient Should finally have it all fixed. EmbyIcons.dll
Neminem 1625 Posted May 18, 2025 Posted May 18, 2025 No worries, I have had fun testing Gave me something to do other that household chores
yocker 1423 Posted May 18, 2025 Author Posted May 18, 2025 3 minutes ago, Neminem said: No worries, I have had fun testing Gave me something to do other that household chores I really appreciate it!!
