yocker 1423 Posted July 22, 2025 Author Posted July 22, 2025 20 minutes ago, keitaro26 said: All the dynamic is working for me, but I noticed that if there are too many icons in horizontal, they overlap. Not sure anything needs changing there are it is an easy to fix issue by rearraging the layouts, but wanted to point it out. Sadly not something i can fix (at least can't think of a way). Not much space to work on with a poster. 1
Neminem 1625 Posted July 22, 2025 Posted July 22, 2025 Change Audio channel to vertical. And audio to vertical. Ohh untick horisontal 1
Neminem 1625 Posted July 22, 2025 Posted July 22, 2025 (edited) Sorry for double posting Edited July 22, 2025 by Neminem
sh0rty 728 Posted July 22, 2025 Posted July 22, 2025 Works as expected except of the limitation mentioned by @keitaro26. But that's not plugins fault. Well done! 1
yocker 1423 Posted July 22, 2025 Author Posted July 22, 2025 (edited) I could maybe look into making it so people could choose on a grid where the icons should be. Problem is i have no idea how to make that, will make it a side project. Many thanks for testing everybody! Nice to hear it works! Edited July 22, 2025 by yocker 1
keitaro26 22 Posted July 22, 2025 Posted July 22, 2025 49 minutes ago, yocker said: I could maybe look into making it so people could choose on a grid where the icons should be. Problem is i have no idea how to make that, will make it a side project. Many thanks for testing everybody! Nice to hear it works! I think it is fine the way it is. Being able to choose which icons appear in which corner and vertical or horizontal is plenty. I just turned everything on to see everything to test it, haha. 1
yocker 1423 Posted July 23, 2025 Author Posted July 23, 2025 (edited) The new version (Version 4.01) is up on Github. Added: Added support for Aspect Ratios. Added button to enable and disable the plugins logging. Changed: Made the detection dynamic so formats, resolution and so on is no longer hardcoded. Fixed: The plugin no longer redraws all posters after a server reset - If you have changed your media files between server shutdowns and some icons are stale or missing then use the "Clear icons cache" button in the settings. (For people who tested the beta, this was not finished when i uploaded that so is not part of the beta.) Note: The dynamic change sadly made it so new icon names has to be used. Like vc.h264.png for the video codec format, please read the readme and/or look at the IconExamples for a look at the naming scheme. It is NOT backwards compatible with the old names! Download here or on Github EmbyIcons Icons with the new names are included in the zip file here, if you still have questions then don't hesitate to ask me. EmbyIcons.zip Edited July 23, 2025 by yocker 1
keitaro26 22 Posted July 23, 2025 Posted July 23, 2025 9 hours ago, yocker said: The new version (Version 4.01) is up on Github. Added: Added support for Aspect Ratios. Added button to enable and disable the plugins logging. Changed: Made the detection dynamic so formats, resolution and so on is no longer hardcoded. Fixed: The plugin no longer redraws all posters after a server reset - If you have changed your media files between server shutdowns and some icons are stale or missing then use the "Clear icons cache" button in the settings. (For people who tested the beta, this was not finished when i uploaded that so is not part of the beta.) Note: The dynamic change sadly made it so new icon names has to be used. Like vc.h264.png for the video codec format, please read the readme and/or look at the IconExamples for a look at the naming scheme. It is NOT backwards compatible with the old names! Download here or on Github EmbyIcons Icons with the new names are included in the zip file here, if you still have questions then don't hesitate to ask me. EmbyIcons.zip 2.65 MB · 0 downloads Just so you know, the version number in the code in the release is still 3.39.0.0
yocker 1423 Posted July 23, 2025 Author Posted July 23, 2025 1 hour ago, keitaro26 said: Just so you know, the version number in the code in the release is still 3.39.0.0 You are correct, don't know what went wrong there as it should be the correct version. Anyway.. Many thanks for reporting it!! I have fixed it now on the github and here is the version with the correct version number. EmbyIcons.dll
yocker 1423 Posted July 24, 2025 Author Posted July 24, 2025 (edited) @CummingCowGirl I'm working on embedding icons into the code it self as a kind of fallback and making it easier for new users. It *should* make it so you can use it in Arch without messing with permissions, only problem being you can only use the icons i provide in the code with your system. Can you provide a list of icons that are crucial for you so i can add them? Like for example. English, spanish, japanese audio, subtitles. Edit: I'm not removing the ability for people to choose custom icons. i'm just adding embedded icons for new users or people that don't need custom ones. Edited July 24, 2025 by yocker
chander421 17 Posted July 24, 2025 Posted July 24, 2025 Some flags i use for audio langages... countries_flag_rounded.zip 3
MediaIntelNUC 36 Posted July 24, 2025 Posted July 24, 2025 Awesome! Sharing is caring, thanx for caring and sharing chander421
yocker 1423 Posted July 25, 2025 Author Posted July 25, 2025 Just some hints at what's being worked on.. Not promising they all get implemented but just some stuff i'm working on/planning. 2
yocker 1423 Posted July 26, 2025 Author Posted July 26, 2025 The new version 5 is up! Download it here or on Githib - EmbyIcons. Added: 1. Icon manager, a tool to see what icons are missing for your videos, it is located in the settings. 2. Profiles to control how each library should look. 3. Setting to use built in icons, custom with built in icons as fallback or only custom icons. This was made to make it all easier for new users and users. 4. Added controllable priorities to icons so the order that the icons are shown can be controlled. Changed: 1. Moved the icon type selector to the Alignment and Layout to clean up the settings. You can now disable icon types by selecting disable in the drop downs instead. 2. Various small code improvements. Bugs: The folder view selector for the icons folder does not go away when pressing ok. Temp fix: Just press next to it or on the X. I just noticed that before i gathered it all into the release. If there are any problems then please don't hesitate to report them to me!! @CummingCowGirl This version should work for you as well as long as you use the built in icons. If you need some more then contact me and i will add them in the next release. EmbyIcons.dll IconExamples.zip 2 1
keitaro26 22 Posted July 26, 2025 Posted July 26, 2025 35 minutes ago, yocker said: The new version 5 is up! Download it here or on Githib - EmbyIcons. Added: 1. Icon manager, a tool to see what icons are missing for your videos, it is located in the settings. 2. Profiles to control how each library should look. 3. Setting to use built in icons, custom with built in icons as fallback or only custom icons. This was made to make it all easier for new users and users. 4. Added controllable priorities to icons so the order that the icons are shown can be controlled. Changed: 1. Moved the icon type selector to the Alignment and Layout to clean up the settings. You can now disable icon types by selecting disable in the drop downs instead. 2. Various small code improvements. Bugs: The folder view selector for the icons folder does not go away when pressing ok. Temp fix: Just press next to it or on the X. I just noticed that before i gathered it all into the release. If there are any problems then please don't hesitate to report them to me!! @CummingCowGirl This version should work for you as well as long as you use the built in icons. If you need some more then contact me and i will add them in the next release. EmbyIcons.dll 3.25 MB · 1 download IconExamples.zip 661.28 kB · 3 downloads I am still seeing the old setting page, and nothing I change and save is being reflected on the posters, only the default audio and subtitle overlays are applied to all libraries.
keitaro26 22 Posted July 26, 2025 Posted July 26, 2025 3 minutes ago, keitaro26 said: I am still seeing the old setting page, and nothing I change and save is being reflected on the posters, only the default audio and subtitle overlays are applied to all libraries. Nevermind, it was a cache issue. 1
yocker 1423 Posted July 26, 2025 Author Posted July 26, 2025 4 minutes ago, keitaro26 said: I am still seeing the old setting page, and nothing I change and save is being reflected on the posters, only the default audio and subtitle overlays are applied to all libraries. Sounds like a browser caching problem which shouldn't happen as the version number does it so the server refreshes the cache when it sees a different number. Try shift -- ctrl - R 1
keitaro26 22 Posted July 26, 2025 Posted July 26, 2025 3 minutes ago, yocker said: Sounds like a browser caching problem which shouldn't happen as the version number does it so the server refreshes the cache when it sees a different number. Try shift -- ctrl - R Yep, it was cache
keitaro26 22 Posted July 26, 2025 Posted July 26, 2025 46 minutes ago, yocker said: The new version 5 is up! Download it here or on Githib - EmbyIcons. Added: 1. Icon manager, a tool to see what icons are missing for your videos, it is located in the settings. 2. Profiles to control how each library should look. 3. Setting to use built in icons, custom with built in icons as fallback or only custom icons. This was made to make it all easier for new users and users. 4. Added controllable priorities to icons so the order that the icons are shown can be controlled. Changed: 1. Moved the icon type selector to the Alignment and Layout to clean up the settings. You can now disable icon types by selecting disable in the drop downs instead. 2. Various small code improvements. Bugs: The folder view selector for the icons folder does not go away when pressing ok. Temp fix: Just press next to it or on the X. I just noticed that before i gathered it all into the release. If there are any problems then please don't hesitate to report them to me!! @CummingCowGirl This version should work for you as well as long as you use the built in icons. If you need some more then contact me and i will add them in the next release. EmbyIcons.dll 3.25 MB · 1 download IconExamples.zip 661.28 kB · 3 downloads Loving the updates! Especially the multiple profiles! 1
ISeeTWizard 29 Posted July 26, 2025 Posted July 26, 2025 46 minutes ago, yocker said: The new version 5 is up! Download it here or on Githib - EmbyIcons. Added: 1. Icon manager, a tool to see what icons are missing for your videos, it is located in the settings. 2. Profiles to control how each library should look. 3. Setting to use built in icons, custom with built in icons as fallback or only custom icons. This was made to make it all easier for new users and users. 4. Added controllable priorities to icons so the order that the icons are shown can be controlled. Changed: 1. Moved the icon type selector to the Alignment and Layout to clean up the settings. You can now disable icon types by selecting disable in the drop downs instead. 2. Various small code improvements. Bugs: The folder view selector for the icons folder does not go away when pressing ok. Temp fix: Just press next to it or on the X. I just noticed that before i gathered it all into the release. If there are any problems then please don't hesitate to report them to me!! @CummingCowGirl This version should work for you as well as long as you use the built in icons. If you need some more then contact me and i will add them in the next release. EmbyIcons.dll 3.25 MB · 1 download IconExamples.zip 661.28 kB · 3 downloads Great work again works well - ok I have some icons missing which I didn’t know before lol time to ignore them thanks for your work 1
yocker 1423 Posted July 26, 2025 Author Posted July 26, 2025 1 minute ago, keitaro26 said: Yep, it was cache And my fault, i forgot to add a simple "pluginversion" in the code so it automatically clears the browser cache, will quickly update that.
yocker 1423 Posted July 26, 2025 Author Posted July 26, 2025 Fixed. It should now correctly automatically update when a new version number is detected. Or just use shift - ctrl - R EmbyIcons.dll 1
yocker 1423 Posted July 26, 2025 Author Posted July 26, 2025 8 minutes ago, ISeeTWizard said: Great work again works well - ok I have some icons missing which I didn’t know before lol time to ignore them thanks for your work Haha yeah, it actually had a hidden benefit for me as i found out i still had a lot of videos with audio languages that will never get used. So started up my remuxer and in the process of saving some GBs. Many thanks to you too!
sh0rty 728 Posted July 26, 2025 Posted July 26, 2025 (edited) Currently installing the newest dll. Well done @yocker! One question though: Currently the icons are used on the Primary image (Poster) of a movie and series (e.g. DV if all episodes match). Is it also possible to append the icons to e.g. the thumbnails and banner in one of a future versions for people that use thumbnail or banner view e.g. for TV shows + to the season posters? Edited July 26, 2025 by sh0rty
yocker 1423 Posted July 26, 2025 Author Posted July 26, 2025 37 minutes ago, sh0rty said: Currently installing the newest dll. Well done @yocker! One question though: Currently the icons are used on the Primary image (Poster) of a movie and series (e.g. DV if all episodes match). Is it also possible to append the icons to e.g. the thumbnails and banner in one of a future versions for people that use thumbnail or banner view e.g. for TV shows + to the season posters? Never thought about that tbh. as i always just used posters. Can absolutely look into that for next version! 1
