alex014 0 Posted December 18, 2014 Posted December 18, 2014 I was referring to the person who mentioned that Unchecking that box fixed the username not found issue I was having. Just trying to be polite
im85288 1493 Posted December 18, 2014 Posted December 18, 2014 I was referring to the person who mentioned that Unchecking that box fixed the username not found issue I was having. Just trying to be polite Can you try it with the new version, you should no longer need to enable that setting on the server 1
tehdartherer 0 Posted December 18, 2014 Posted December 18, 2014 Hehe, np, found it by chance. It can comfirm that it is now working, with the new beta Addon + hide usernames checked. Thanks!
mata7 45 Posted December 22, 2014 Posted December 22, 2014 (edited) im having the same proble, i check the config and everyting should be ok, user name and password, i try hide user and unhide and dont make any diferent, im using Last media browser server beta, MB Kodi 0.9.740, kodi RC3, i dont know what to do anymore, i will really apreciate some help thanks in advanced Edited December 22, 2014 by mata7
Angelblue05 4132 Posted December 22, 2014 Posted December 22, 2014 (edited) @@mata7 If you are sure your username and password combination is correct, can you go into the settings section and set the debug level to 1 or 2 and post a link to your log here? You can follow the process here for a simple way to upload your log: http://kodi.wiki/view/Log_file/Easy (NOTE - you only need to set the debug level on the xbmb3c addon settings) It is a different issue than what was posted here. Please start a new thread with your issue. I will try to help you You just need to post your XBMC.log file (XBMB3C debug is contained within it), once you enable the debug and capture the error. Restarting XBMC will start a new log. Edited December 22, 2014 by Angelblue05
mata7 45 Posted December 22, 2014 Posted December 22, 2014 i create a diferent user and that work, i dont know why do i need to create a diferent user for this 2 work
Angelblue05 4132 Posted December 22, 2014 Posted December 22, 2014 You don't have to. Something weird is happening for sure. A log would be helpful in seeing what the add-on is doing when it tries to connect to your first user. 1
mata7 45 Posted December 23, 2014 Posted December 23, 2014 i fix it and it was my fault, i add the password to my default user name and that work, i maybe have change something and forgot to add the password back, anyway thanks for you help
Angelblue05 4132 Posted December 23, 2014 Posted December 23, 2014 That's great news, I'm glad you were able to figure it out.
