jcricketlegs 0 Posted November 26, 2014 Posted November 26, 2014 (edited) Hi all, new to MB3 and am trying to get my XBMB3C connected to my server on windows. Firstly it said server detected succeeded and then it states unable to connect to server. I have put in the IP address in the primary server address ( I got this from pop up when it said server detected succeeded, is that correct?) Port is auto filled Username keeps stating username not found even though I know it is correct. Update, now taken out username and it detected server but now getting incorrect url ; unable to connect to server Any help greatly appreciated. Simon Edited November 26, 2014 by jcricketlegs
Angelblue05 4132 Posted November 26, 2014 Posted November 26, 2014 (edited) What I would suggest you to try is once you enter your username and password within the XBMB3C/MediaBrowser add-on, restart XBMC/Kodi (ignore the errors) and see if the error persists. Edited November 26, 2014 by Angelblue05
jcricketlegs 0 Posted November 27, 2014 Author Posted November 27, 2014 HI, this still is not functioning and still getting incorrect url ; unable to connect to server after it stating that the server had been detected....
Angelblue05 4132 Posted November 27, 2014 Posted November 27, 2014 (edited) Can you please confirm the url has been saved to the add-on settings by navigating to Enabled add-ons > Video add-ons > Media Browser/XBMB3C > Configure? You can restart XBMC/Kodi, if you had to insert the url manually. Sometimes I find it doesn't save properly using the auto-detect. If it still doesn't work, then we'll need a log to see what's going on, instead of just guessing. You will need to enable the debug log 1 -info in the Media Browser/XBMB3C add-on settings (advanced tab / it's the last one). You will need to post your xbmc log. If you are not familiar with logs, you can follow this: http://kodi.wiki/view/Log_file/Easy and/or post the content of your log directly in pastebin.com, using the python syntax and paste the direct link to it in your post. Edited November 27, 2014 by Angelblue05
jcricketlegs 0 Posted November 27, 2014 Author Posted November 27, 2014 Hi there, thanks for response. Probably being dumb but what is the actual url as I don't think I have ever put it in!? Presumably it was just on auto detect?
Angelblue05 4132 Posted November 27, 2014 Posted November 27, 2014 It's a valid question, the url is the local ip you use to access your Media Browser server. Sent from my iPhone using Tapatalk
jcricketlegs 0 Posted November 27, 2014 Author Posted November 27, 2014 Thanks, so the localhost url or the remote access url?
Angelblue05 4132 Posted November 27, 2014 Posted November 27, 2014 (edited) You could technically use either (if you want to access a server outside your network), but in your case, you will want to go with the localhost/internal ip address (mine is 192.168.0.190, for example). Sent from my iPhone using Tapatalk Edited November 27, 2014 by Angelblue05
saitoh183 137 Posted November 27, 2014 Posted November 27, 2014 You could technically use either (if you want to access a server outside your network), but in your case, you will want to go with the localhost/internal ip address (mine is 192.168.0.190, for example). Sent from my iPhone using Tapatalk It is also case sensitive
dark_slayer 103 Posted November 30, 2014 Posted November 30, 2014 Thanks, so the localhost url or the remote access url?I'm not sure why, but localhost never works (in other xbmc addons as well). It surely wouldn't work if it's not the same machine, but if you are running xbmc and testing this on your the same box as your mb3 server then you should be able to use 127.0.0.1 In any case your local IP should work, but don't enter http in front
alex014 0 Posted December 14, 2014 Posted December 14, 2014 Hi. Can someone tell me where to find the proper username. I keep getting this error. I think i am entering the corect name but it is not working. I am entering the same name i use to log in to mediabrowser server. Is this correct? Thank you for any help
Angelblue05 4132 Posted December 14, 2014 Posted December 14, 2014 Yes, the username is the same as the one you use to login to your Media Browser server. Do you get the error even after restarting XBMC/Kodi? If so, you can always verify your information here: users > username > Appdata > Roaming > Kodi or XBMC > userdata > addon_data > plugin.video.xbmb3c > settings.xml (make sure id=username and id=password fields are correct)
alex014 0 Posted December 14, 2014 Posted December 14, 2014 Thank you for the help I will verify my info is correct. It does happen after I restart kodi. I also tried installing different combinations of kodi or Gotham and the beta and stable repo. That is why I figured I was putting in the wrong user name
alex014 0 Posted December 15, 2014 Posted December 15, 2014 I checked the settings file and everything seemed to be correct. Is there anything else I could try?
im85288 1493 Posted December 15, 2014 Posted December 15, 2014 If you are sure your username and password combination is correct, can you go into the settings section and set the debug level to 1 or 2 and post a link to your log here? You can follow the process here for a simple way to upload your log: http://kodi.wiki/view/Log_file/Easy (NOTE - you only need to set the debug level on the xbmb3c addon settings)
tehdartherer 0 Posted December 17, 2014 Posted December 17, 2014 Had the same issue. The option to hide the username on the login page, in the advanced user configuration, was activated. Disabling it solved the problem.
xnappo 1611 Posted December 17, 2014 Posted December 17, 2014 Had the same issue. The option to hide the username on the login page, in the advanced user configuration, was activated. Disabling it solved the problem. @@Luke - FYI
xnappo 1611 Posted December 18, 2014 Posted December 18, 2014 Somehow hiding the user name on the server web page prevents the client from seeing it?
Luke 42234 Posted December 18, 2014 Posted December 18, 2014 yes that's correct. when you query for public users it wont be returned in the list at all. they have to login manually by typing in their username and password
xnappo 1611 Posted December 18, 2014 Posted December 18, 2014 Okay - maybe we are incorrectly checking user names against the public user list. @@im85288? (or @ , can't remember who did this last )
Luke 42234 Posted December 18, 2014 Posted December 18, 2014 yea, the easy answer is don't do that, but if you tell me what you're trying to accomplish i can help give you a better way
alex014 0 Posted December 18, 2014 Posted December 18, 2014 Thanks for the advice. I unchecked the box and now its working properly
Luke 42234 Posted December 18, 2014 Posted December 18, 2014 Thanks for the advice. I unchecked the box and now its working properly if you're talking to me, that wasn't advice for you. you should configure how you want. i can help them get it squared away.
im85288 1493 Posted December 18, 2014 Posted December 18, 2014 There's a new version available in the beta repo where this should work (0.9.737). Please confirm either way 1
