Wane2506 1 Posted May 9, 2025 Posted May 9, 2025 @LukeWhen I manually changed the metadata, emby didn't remove the old metadata, so it became 2 different titles with the same folder. screen-20250509-165049.mp4
Luke 42290 Posted May 9, 2025 Posted May 9, 2025 @Wane2506what exactly do you feel that it didn't remove?
Wane2506 1 Posted May 10, 2025 Author Posted May 10, 2025 I have to identify twice for old data to be deleted
Luke 42290 Posted May 10, 2025 Posted May 10, 2025 17 minutes ago, Wane2506 said: I have to identify twice for old data to be deleted HI there, can you please provide a specific example? How to Report a Problem Thanks !
Wane2506 1 Posted May 10, 2025 Author Posted May 10, 2025 Looks like the problem is the same as what happened in this post https://emby.media/community/index.php?/topic/135139-bug-metadata-duplicated-infos/ Emby detected 2 folders in one path, I will try to delete the path and try to pair again, I tried to identify the other folder path, and the other library, everything is normal, only this library path is problematic.
