Solution guunter 49 Posted May 30, 2025 Solution Posted May 30, 2025 2 minutes ago, Ladiesman0217 said: Where in the settings for radar and sonar is that? It’s called connect 1
Ladiesman0217 14 Posted May 30, 2025 Author Posted May 30, 2025 1 minute ago, guunter said: It’s called connect Holy crap there it is. Thank you so much. I'm going to check this out 1
Ladiesman0217 14 Posted May 31, 2025 Author Posted May 31, 2025 Ok I have Connect set up for Emby within both Radarr and Sonarr. Since those services are now communicating with Emby and triggering Emby to scan for changes, should I just turn off the Realitime monitoring since it's not working anyways?
Luke 42288 Posted May 31, 2025 Posted May 31, 2025 1 hour ago, Ladiesman0217 said: Ok I have Connect set up for Emby within both Radarr and Sonarr. Since those services are now communicating with Emby and triggering Emby to scan for changes, should I just turn off the Realitime monitoring since it's not working anyways? That probably makes sense, yes. 1
scegg 12 Posted December 19, 2025 Posted December 19, 2025 Currently, INOTIFY support is NOT included in WSL2 on Windows. If you run a Linux based docker container on Windows and use volume mapped from Windows path (WSL2 folder excluded), there will NOT be any INOTIFY event raised when files changing. This should be, but not, nor planned, fixed by WSL. Please go there to complain instead lol.
