thezfunk 1 Posted May 4, 2025 Posted May 4, 2025 Hi, When I initially started and scanned my library I didn't have the Collections library enabled/selected. I have since enabled it but it only populates with new movies. How do I force it to go back through and build collections with all the movies that were already there?
Solution Luke 42176 Posted May 5, 2025 Solution Posted May 5, 2025 Hi, please try refreshing the metadata on those movies and see if that helps.
thezfunk 1 Posted May 5, 2025 Author Posted May 5, 2025 1 hour ago, Luke said: Hi, please try refreshing the metadata on those movies and see if that helps. Refresh with erase and over write?
thezfunk 1 Posted May 5, 2025 Author Posted May 5, 2025 Nevermind. A refresh of missing data worked. I didn't have to over write everything. 1
