ISeeTWizard 29 Posted May 4, 2025 Posted May 4, 2025 Hi I have some libraries for my movies and entering them over a localy mapped drive on my Linux System where the Emby server runs on (loaded over fstab) works well as long as I don't play some 4k movies (some working some not) When I than instead load as folder the smb path to my NAS where my movies are the movies are playing back correctly without studering every x seconds but for that he can't save the nfo files and images directly in the media folder So for the one I can write my files and not playback every 4k video and for the other I can playback all movies but can't save the files 2025-05-04 15:22:14.148 Error ProviderManager: Error saving to smb://192.168.178.20/Media/Movies/german/Pacific Rim (2013)/fanart.jpg. Create Handle Failed: Movies\german\Pacific Rim (2013). NTStatus: FILE_DOES_NOT_EXIST. 2025-05-04 15:22:14.163 Info HttpClient: GET .... And for both I'm using the same username and password - I have absolutely no clue where my issue could come from at the moment Does anyone here has a clue?
ISeeTWizard 29 Posted May 4, 2025 Author Posted May 4, 2025 Here some more data from the log: Â 2025-05-04 16:08:27.709 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.8.11.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 6.8.0-59-generic (buildd@lcy02-amd64-035) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubunt Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.IOException: System.IO.IOException: Create Handle Failed: Movies\german\Pacific Rim (2013). NTStatus: FILE_DOES_NOT_EXIST at EzSmb.Transports.Shares.Handlers.Bases.HandlerBase..ctor(SmbType smbType, ISMBFileStore store, String path, HandleType handleType, NodeType nodeType, HandleArgs args) at EzSmb.Transports.Shares.Smb2Share.GetHandler(String path, HandleType handleType, NodeType nodeType, HandleArgs args) at EzSmb.Transports.Shares.Bases.ShareBase.CreateFolder(Node node, String folderName) at EzSmb.Node.CreateFolder(String folderName, String relatedPath) at Emby.Server.Implementations.IO.SmbFileSystem.CreateDirectory(String path) at NfoMetadata.Savers.BaseNfoSaver.SaveToFile(Stream stream, String path, LibraryOptions libraryOptions, CancellationToken cancellationToken) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.SaveMetadata(BaseItem item, LibraryOptions libraryOptions, ItemUpdateType updateType, IMetadataSaver[] savers, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void .ctor(EzSmb.Params.Enums.SmbType, SMBLibrary.Client.ISMBFileStore, System.String, EzSmb.Transports.Shares.Handlers.Enums.HandleType, EzSmb.NodeType, EzSmb.Transports.Shares.Handlers.HandleArgs) 2025-05-04 16:08:27.722 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i "http://127.0.0.1:8096/Items/File?Id=smb%3A%2F%2F192.168.178.20%2FMedia%2FMovies%2Fgerman%2FPacific+Rim+-+Uprising+(2018)%2FPacific+Rim+-+Uprising+(2018)+-+2160p.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2025-05-04 16:08:28.286 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 - Succeeded Â
ISeeTWizard 29 Posted May 4, 2025 Author Posted May 4, 2025 I tried loading it as CIFS and even activated NFS on my Synology as a test (found something like that in the forums here 192.168.178.20:/volume1/Media /mnt/Media nfs defaults 0 0 But nothing seems to help
Solution ISeeTWizard 29 Posted May 4, 2025 Author Solution Posted May 4, 2025 OK - after 4 hours I wanted to gave up but I tested the 4k videos in the browser and here it worked. So I checked my TV and found out that it was connected to the 2.4GHz Wifi instaed of my 5GHz- now the movies are running normally grmpf 1
Luke 42243 Posted May 4, 2025 Posted May 4, 2025 HI, just as a heads up, there are some cases with the 4.8 server where your smb credentials are not being applied. This has been resolved for the upcoming 4.9 server release. Thanks.
