rekit 16 Posted May 1, 2025 Posted May 1, 2025 Why it would be helpful: When using match frame rate and/or match resolution with any app - Emby included - (usually with external streaming devices rather than native tv apps), the display will briefly go black while the frame rate and/or resolution are switching, and audio will start playing while the screen is still black. Some apps (Smarttube is one of them) have the option to add a brief delay (0.25, 0.5, 0.75 seconds etc) to playback so that playback doesn't start while the display is still black, and if you choose a duration that works for your setup, the timing makes playback feel seamless. 2
Luke 42243 Posted May 2, 2025 Posted May 2, 2025 Hi, yes this has come up before and it makes sense. Thanks. 1
voodoo5_6k 29 Posted July 22, 2025 Posted July 22, 2025 That's exactly one of those details that would make emby even more shiny I'd also like to see something like this. Playback always starts before synchronization between all devices is complete and I have to skip back when the screen finally comes "alive". 1
