FrostByte 5453 Posted May 1, 2025 Posted May 1, 2025 Long Press doesn't work on my 2018 Q8FN. Neither the Home Screen or the OSD option do a thing when long pressing the OK button Server 4.9.0.51 App: 2.0.8 Steps: Settings Playback Video long press action (set to whatever, none of them work) Is this a limitation of my older model, or is a change in the code needed for older models? Can the option be grayed out or not shown for older models if not possible as it's confusing. Also, can we get the X back on the SFN window like it was before? This would eliminate going back to the OSD to turn off SFN.
Luke 42239 Posted May 1, 2025 Posted May 1, 2025 Hi, if you plug in a usb keyboard, does it work with the enter key?
FrostByte 5453 Posted May 1, 2025 Author Posted May 1, 2025 6 minutes ago, Luke said: Hi, if you plug in a usb keyboard, does it work with the enter key? No, with a USB keyboard it also acts just like it does with the setting set to None. It just pauses/restarts playback when long pressing Enter 1
