gong700 4 Posted April 30, 2025 Posted April 30, 2025 Because I need to show my users “Recently released movies and TV series(Tv shows)”. For movies, there is an option of "Recently Released Movies" on the Home screen, but there is no such option for TV series. So, dear Emby team, could you please add a "Recently Released Tv shows" option on the Home screen? 2 1 1
ebr 16337 Posted May 5, 2025 Posted May 5, 2025 Hi. Like all feature requests, we will monitor this for interest. Thanks. 1
Happy2Play 9812 Posted May 5, 2025 Posted May 5, 2025 I would assume it would be exactly the same as Latest TV as it will show the show you just added episodes for first ie Latest Episode date added, correct? But a real definition of "Recently Released Tv shows" would need to be established as are we talking about a Show or the Episode added? Same as the only difference in the "Recently Released Movies" is it is by Release date and Latest is by "date added"
GrimReaper 4898 Posted May 5, 2025 Posted May 5, 2025 1 minute ago, Happy2Play said: I would assume it would be exactly the same as Latest TV as it will show the show you just added episodes for first ie Latest Episode date added, correct? I wouldn't think so, I'd expect it to list TV shows based on Latest episode date aired/released, regardless of its Date added, as Latest row does.
Happy2Play 9812 Posted May 5, 2025 Posted May 5, 2025 2 minutes ago, GrimReaper said: I wouldn't think so, I'd expect it to list TV shows based on Latest episode date aired/released, regardless of its Date added, as Latest row does. So a duplicate of a row that already exist. I guess then one could eliminate Latest Rows would be the only benefit.
GrimReaper 4898 Posted May 5, 2025 Posted May 5, 2025 (edited) Not a duplicate. Show A: Last episode aired: 15/04/25 Added: 18/04/25 Show B: Last episode aired: 16/04/25 Added: 17/04/25 Latest row: A—>B Recently Released TV row: B—>A Edited May 5, 2025 by GrimReaper
Happy2Play 9812 Posted May 5, 2025 Posted May 5, 2025 2 minutes ago, GrimReaper said: Not a duplicate. Show A: Last episode aired: 15/04/25 Added: 18/04/25 Show B: Last episode aired: 16/04/25 Added: 17/04/25 Latest row: A—>B Recently Released TV row: B—>A Pretty sure that is exactly what my Latest TV row already does.
GrimReaper 4898 Posted May 5, 2025 Posted May 5, 2025 (edited) 5 minutes ago, Happy2Play said: Pretty sure that is exactly what my Latest TV row already does. It shouldn't, it should be based on Last Episode Date Added, not Last Episode Release Date. Edit: To make it more extreme: Show A: Last episode aired: 12/06/19 Added: 18/04/25 Show B: Last episode aired: 16/04/25 Added: 17/04/25 Latest row: A—>B Recently Released TV row: B... (A would likely not even be in the list) Edited May 5, 2025 by GrimReaper 1
Happy2Play 9812 Posted May 5, 2025 Posted May 5, 2025 Okay I know why mine has always been that way as I have Timelord so nothing in Emby is by date added it is always Release date. 3
ebr 16337 Posted May 5, 2025 Posted May 5, 2025 This would have even more overlap than the Latest/Recently release movies section because there is no "lag" in home releases for TV like there is for movies but, also, we would have to define what is "recently released" in the context of a TV show. Is it latest episode or first episode? An argument can be made for both but first episode would produce the least amount of overlap with the "latest" row. 1 1
Neminem 1623 Posted May 5, 2025 Posted May 5, 2025 So should it be Premier date of Tv show, regardless of episodes added date.
Happy2Play 9812 Posted May 5, 2025 Posted May 5, 2025 Just now, Neminem said: So should it be Premier date of Tv show, regardless of episodes added date. But then a show with many seasons would always be buried behind everything newer.
ebr 16337 Posted May 5, 2025 Posted May 5, 2025 1 minute ago, Happy2Play said: But then a show with many seasons would always be buried behind everything newer. Right but what is the point of this row if we don't do that? it would almost always be the same as the "Latest" row... So, using actual series premiere date gives you a row of brand new series.
GrimReaper 4898 Posted May 5, 2025 Posted May 5, 2025 I don't doubt userbase will be split on this one, as it so often happens. I reckon it all falls down to what would the actual scope ultimately be: accurately reflect episodes Release dates, avoid overlapping with Latest row as much as possible or show TV shows only regardless of episodes/number of seasons?
crusher11 1143 Posted May 5, 2025 Posted May 5, 2025 1 hour ago, ebr said: there is no "lag" in home releases for TV like there is for movies There is if you're getting them on disc, and/or ever add old shows. I recently added Seinfeld to my server, for example.
ebr 16337 Posted May 5, 2025 Posted May 5, 2025 1 hour ago, crusher11 said: There is if you're getting them on disc, and/or ever add old shows. I recently added Seinfeld to my server, for example. Yes, but that is the odd case not the common one.
Armageus 78 Posted May 6, 2025 Posted May 6, 2025 On 30/04/2025 at 14:45, gong700 said: Because I need to show my users “Recently released movies and TV series(Tv shows) No you don't - you could just tell them, given that it's only a few friends or family surely? 21 hours ago, ebr said: because there is no "lag" in home releases for TV like there is for movies 18 hours ago, ebr said: Yes, but that is the odd case not the common one. And there was me thinking that Emby was for legitimately acquired media?
ebr 16337 Posted May 6, 2025 Posted May 6, 2025 20 minutes ago, Armageus said: And there was me thinking that Emby was for legitimately acquired media TV shows are broadcast and can be legally recorded.
Luke 42244 Posted May 17, 2025 Posted May 17, 2025 On 5/6/2025 at 8:39 AM, Armageus said: No you don't - you could just tell them, given that it's only a few friends or family surely? And there was me thinking that Emby was for legitimately acquired media? Hi, yes that is what Emby is for.
Luke 42244 Posted May 17, 2025 Posted May 17, 2025 On 5/5/2025 at 1:38 AM, gong700 said: Is anyone paying attention to this post? Hi @gong700yes we are monitoring this feature request for community feedback, just as we do all other feature requests. Thanks ! 1
