rusty_nail 4 Posted April 28, 2025 Posted April 28, 2025 The recent emby update pushed out as at 27/4? Has removed emby from appearing in android auto. I use the app frequently to play audiobooks and stream radio. Is this a feature that has been removed intentionally or by mistake? On 5/11/2024 at 11:07 PM, ebr said: Hi. It does. We fully support the Android Auto (and CarPay) UI which specifically does NOT allow video (for safety reasons).
Luke 42242 Posted April 29, 2025 Posted April 29, 2025 @rusty_nailHi, what Emby app version do you have installed?
reginold 1 Posted April 29, 2025 Posted April 29, 2025 48 minutes ago, Luke said: @rusty_nailHi, what Emby app version do you have installed? Hi Luke, my apologies, this error was self inflicted. Android put the app into deep sleep which disabled it as emby was noted at the highest battery consuming app on my phone. After making my post I discovered this and wasn't able to undo it. Fwiw, app version is 3.4.62 1
