muzicman0 85 Posted April 27, 2025 Posted April 27, 2025 It took me way too long to figure this out, and not at all sure there isn't a way to do this easier, but this is working. I used shared drives (SMB) for all of my media files, so my TV, Recorded TV, and movies all reside on a remote disk. I mount the SMB shares in my fstab file at boot with something like this (disclaimer: I am using Ubuntu 24.04): //10.3.0.140/Movies /media/Movies cifs credentials=/home/muzicman0/.smbcredentials,uid=1000,gid=1000 0 0 //10.3.0.140/TV/TV /media/TV cifs credentials=/home/muzicman0/.smbcredentials,uid=1000,gid=1000 0 0 The Problem: my normal login user can write or delete files/folder, but my group can only read. So even though I added the 'emby' user to my group, I couldn't delete files from within Emby. The solution: I changed each mount line in my fstab to something like this: //10.3.0.140/Movies /media/Movies cifs credentials=/home/muzicman0/.smbcredentials,file_mode=0770,dir_mode=0770,uid=1000,gid=1000 0 0 //10.3.0.140/TV/TV /media/TV cifs credentials=/home/muzicman0/.smbcredentials,file_mode=0770,dir_mode=0770,uid=1000,gid=1000 0 0 This now allows group read & write, not just read. I think technically it allows execute as well. You'll also need cifs-utils installed to mount via CIFS: sudo apt install cifs-utils The command to add the emby user into your username group (uid/gid 1000 in my example above) is: usermod -a -G {group_name} emby You may need to preface that command with sudo, don't remember for sure. If you get a permission denied, then use sudo. Once the above is done, you either reboot, or re-mount your drives. I hope this helps someone. 1
Luke 42243 Posted April 27, 2025 Posted April 27, 2025 Thanks for sharing. I'm sure this will be useful.
muzicman0 85 Posted April 28, 2025 Author Posted April 28, 2025 (edited) I can't figure out how to edit my post for some reason, but I was going to add that something I didn't think about was that my Backups also go to a remote SMB drive, so I had to also do the same thing for that mount. [EDIT: Weird, this post shows me as the author and lets me edit. the OP doesn't.] Edited April 28, 2025 by muzicman0 update 1
