toudou 1 Posted April 27, 2025 Posted April 27, 2025 I'm not sure what I'm doing wrong, I have intel GPU drivers properly installed, `intel-gpu-top` works properly too. emby-server is installed via snap, the process is running with root, I'm not sure why I'm getting `Message": "Failed to initialize VA /dev/dri/renderD128. Error -1` in the logs. Any idea ? hardware_detection-63881381806.txt
toudou 1 Posted April 27, 2025 Author Posted April 27, 2025 More breadcrumbs: LD_LIBRARY_PATH=/opt/emby-server/lib ./ffmpeg -vaapi_device /dev/dri/renderD128 ffmpeg version 5.1-emby_2023_06_25 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (crosstool-NG 1.25.0) Execution Date: 2025-04-27 21:30:24 [AVHWDeviceContext @ 0x182a1c0] libva: dlopen of /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so failed: /opt/emby-server/lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so) [AVHWDeviceContext @ 0x182a1c0] libva: /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so init failed [AVHWDeviceContext @ 0x182a1c0] Failed to initialise VAAPI connection: -1 (unknown libva error). Device creation failed: -5. Failed to set value '/dev/dri/renderD128' for option 'vaapi_device': Input/output error Error parsing global options: Input/output error EXIT
TMCsw 259 Posted April 27, 2025 Posted April 27, 2025 You are not doing anything wrong as emby does not yet support this iGPU... ...you can fallow along here:
RanmaCanada 502 Posted April 27, 2025 Posted April 27, 2025 You need to be running windows for this cpu to work. IAFIK it does not work on Linux, yet.
TMCsw 259 Posted April 27, 2025 Posted April 27, 2025 32 minutes ago, RanmaCanada said: IAFIK it does not work on Linux, yet. Yes it does! (as shown in thread linked above) It's just emby (and some other(s)) that do not support it Yet.
RanmaCanada 502 Posted April 28, 2025 Posted April 28, 2025 3 hours ago, TMCsw said: Yes it does! (as shown in thread linked above) It's just emby (and some other(s)) that do not support it Yet. That is what I meant. If you want it to work with Emby, you need to be running Windows. Sorry I wasn't more clear.
