BillOatman 597 Posted April 26, 2025 Posted April 26, 2025 (edited) Emby is fed this in its XML file: <programme start="20250427020000 +0000" stop="20250427043000 +0000" channel="TSN5.ca"> <category lang="en">Sports</category> <category lang="en">Lacrosse</category> <category lang="en">Series</category> <date>2025-04-27</date> <desc lang="en">Quarterfinal.</desc> <episode-num system="dd_progid">EP00038870.0852</episode-num> <icon src="https://zap2it.tmsimg.com/assets/GNLZZGG001Y9F6P.jpg"></icon> <length units="minutes">150</length> <title lang="en">NLL Lacrosse ᴸᶦᵛᵉ Rochester Knighthawks at Vancouver Warriors</title> <live /> </programme> What displays in the Emby Windows app is correct: The top is the guide line and the bottom what shows in the detail when that line is selected: However, this is what shows in the AndroidTV app on a Shield (if that matters). Note the team names are not displayed. Now sure if it is the ᴸᶦᵛᵉ causing a problem or what. This is common for a lot things in my guide, and they all seem to be the ᴸᶦᵛᵉ ones. Also worth noting is there is a linefeed in the title after the live Edited April 26, 2025 by BillOatman
Luke 42243 Posted April 26, 2025 Posted April 26, 2025 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
BillOatman 597 Posted April 26, 2025 Author Posted April 26, 2025 7 minutes ago, Luke said: Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. The standard Android app on my Shield displays it correctly, Also note that I added detail to the bottom of my post while you were responding that there is a linefeed in the title. 1
Solution ebr 16336 Posted April 26, 2025 Solution Posted April 26, 2025 2 hours ago, BillOatman said: that there is a linefeed in the title. That's the problem. The TV app is respecting that and advancing to another line. However, the UI only has room for one line.
