elche27 3 Posted April 25, 2025 Posted April 25, 2025 (edited) Buenas tardes tengan ustedes, luego de realizar el ultimo upgrade no pude volver a ver los canales que esta en mi tvheaend server....cuando agrego el source de tvh trae los canales pero cuando quiero reproducirlo me sale este error: PD: con otra aplicacion como kodi si puedo ver los canales...y antes del upgrae estaba viendolos que podria estar pasando? embyserver(5).txthardware_detection-63881197136.txtembyserver-63881197020.txt Edited April 25, 2025 by elche27 agregar un detalle
Luke 42239 Posted April 25, 2025 Posted April 25, 2025 Hi, your live tv url is sending back an error response saying 503 unavailable. Can you find out why?
elche27 3 Posted April 25, 2025 Author Posted April 25, 2025 No, i need help....this happened just after upgrade to 4.8.11...even more, in th same pc from error...i reach all my channels with KODI so the routes are ok...maybe somethings broke on emby after upgrade coz i configure my tvh as source, get channel from tvh BUT i cant watch it....there is no more hint on logs?...just that? thank in advance
Luke 42239 Posted April 25, 2025 Posted April 25, 2025 That's coming from the remote server. Is it a remote server hosting the content? Can that server be rebooted?
elche27 3 Posted April 25, 2025 Author Posted April 25, 2025 (edited) emby connect to my tvh server...yes i can reboot...i already did 3 times...even more, tried to create other user coz i though was a privileges thing but nothing...still analazng PS: tried unistall emby...and install 4.7.14 again but dont even get to panel...nothing happen...is worst so i re instlled it 4.8.11 and now get panel BUT still cant watch channels Edited April 25, 2025 by elche27
elche27 3 Posted April 25, 2025 Author Posted April 25, 2025 resuelto, al parecer un problema de profile!! solved....some profile problem 1
