furnibird 6 Posted April 24, 2025 Posted April 24, 2025 Hi all I am running my server on Windows with dedicated pc. No issues so far with internal devices. My issue is I have a few devices outside my network when my ISP change my ip they can't connect. Without sorting a static ip what are my options?
Gilgamesh_48 1243 Posted April 24, 2025 Posted April 24, 2025 I think Emby connect allows that. But i do not know for sure as my IPs never change.
furnibird 6 Posted April 24, 2025 Author Posted April 24, 2025 I have a few users and only I can link my email for emby connect. I need a DNS service after further research.
Luke 42176 Posted April 24, 2025 Posted April 24, 2025 35 minutes ago, furnibird said: I have a few users and only I can link my email for emby connect. I need a DNS service after further research. Why can you only link your email?
furnibird 6 Posted April 24, 2025 Author Posted April 24, 2025 (edited) I want to have same email for all users but when I try it says the email is already associated to a ebmy connect account. Don't want to have to keep entering details every time my ISP changes my ip. I have a few family members who are not tech savvy. Edited April 24, 2025 by furnibird
Luke 42176 Posted April 24, 2025 Posted April 24, 2025 Quote Don't want to have to keep entering details every time my ISP changes my ip Why would you have to do that with emby connect?
Gilgamesh_48 1243 Posted April 24, 2025 Posted April 24, 2025 8 minutes ago, furnibird said: I want to have same email for all users but when I try it says the email is already associated to a ebmy connect account. Don't want to have to keep entering details every time my ISP changes my ip. I have a few family members who are not tech savvy. You are not going to be able to have the same email for all users if you want to use Emby connect. If the reason you want the same Email across the board for users for some other reason then a potential workaround is to use a mailing list so you can send things to everybody at once. If you want to use the same email is for user convenience then you will just have to teach your users what they need to know to use Emby connect. I really cannot understand why having the same email for all your users is at all good but each to their own. It seems like your only option is a static IP. If that costs extra then you need to decide if it is worth it.
furnibird 6 Posted April 24, 2025 Author Posted April 24, 2025 Am i correct in understanding I need to register a different email for each user so that they can use emby connect ?
seanbuff 1353 Posted April 24, 2025 Posted April 24, 2025 10 minutes ago, furnibird said: Am i correct in understanding I need to register a different email for each user so that they can use emby connect ? Correct. Emby Connect
Luke 42176 Posted April 24, 2025 Posted April 24, 2025 15 minutes ago, furnibird said: Am i correct in understanding I need to register a different email for each user so that they can use emby connect ? Well can't it just be their own email?
furnibird 6 Posted April 24, 2025 Author Posted April 24, 2025 It can be their own email. Family friend who is elderly has access but doesn't really use email etc. Plus a pain when having to enter email and password everytime my ip is changed. Easy for some, not always easy for other. I understand now. Sorry for the confusion. I will look into static ip when I change ISP in 6 months. Thanks all. 1
seanbuff 1353 Posted April 24, 2025 Posted April 24, 2025 26 minutes ago, furnibird said: Plus a pain when having to enter email and password everytime my ip is changed. This is not required. Users will only ever have to sign in once per device. Emby Connect automatically handles your IP changes behind the scenes, that's what it was designed for. Your IP changes will remain transparent to the end users.
furnibird 6 Posted April 24, 2025 Author Posted April 24, 2025 Perfect. Besides the volume issue I have with some files I had set up server months ago and it's been great. Never bothered with connect until this issue. Thanks for the clarification. 1
