mangis 10 Posted November 25, 2014 Posted November 25, 2014 Hi Scott Experiencing the same issue that this thread relates to, although that was for the Windows 8.1 app. I'm running WP App 8.0.63.0 on Lumia 930 Dev Preview on Cyan connecting to Server 3.0.5441.2 (beta) When I exit and confirm I want to close the player FFMPEG continues to runs, using a fair chunk of the CPU.So when I start playing something else multiple instances start to build up, I also noticed that a second instance of FFMPEG also start when I scrub forward in the video I'm playing, not sure if this is normal and the original should have been killed. , It's possible that it's something just to do with my server and I'm planning a complete reinstall this weekend so the issue may resolve itself then but thought I'd raise it just in case so if you do think it's an issue there is also a window in which I can supply logs from the current install. Thanks
ScottIsAFool 517 Posted November 25, 2014 Posted November 25, 2014 Hmm, it should be killing the ffmpeg thread when you stop watching a video. Will need to investigate.
mangis 10 Posted November 25, 2014 Author Posted November 25, 2014 The server is running on Windows Server 2012 R2 Essentials if that makes any difference.
docmarmo 3 Posted February 18, 2015 Posted February 18, 2015 I'm now having the same issue... Latest beta and devs do not correct the problem.
