AngelSing 49 Posted April 27, 2025 Author Posted April 27, 2025 7 minutes ago, ebr said: It used to have this but almost no one used it and maintaining and supporting it properly was just too expensive. I have been using Emby for a short time, no more than 6 to 8 months, I think. I used to be on Plex, then I moved to Jellyfin, but eventually I ended up with Emby. I would have liked to see those features, but for now I will have to settle for what is available. Anyway, thank you very much.
Happy2Play 9814 Posted April 27, 2025 Posted April 27, 2025 1 hour ago, polaris70 said: Hi Happy2Play, Could you please (if possible) give me "custom css "fill" code" to test for my collection. Thank you Here you go. img.coveredImage-contain { object-fit: fill; } 2
DarWun 357 Posted April 27, 2025 Posted April 27, 2025 I did not realize the fix for the collection image scaling differently for collections than other Coverart treatments was this easy. Thanks for this @Happy2Play!
polaris70 18 Posted April 27, 2025 Posted April 27, 2025 37 minutes ago, Happy2Play said: Here you go. img.coveredImage-contain { object-fit: fill; } Thank you. It works! Hopefully, some other devices like AppleTV 4K can also apply it in the future, maybe by setting a transparency border instead of a solid border.
AngelSing 49 Posted April 27, 2025 Author Posted April 27, 2025 3 hours ago, ebr said: There are a number of different image treatments that are quite noticeable because they put discs into the image showing how many items are in the collection. Look, @ebr, this is what I do, but in the end the CD icons never appear in the cover thumbnail. I do not know if I am missing something. Could you correct me? 27-04-2025_12-44-20.mp4
ebr 16354 Posted April 27, 2025 Posted April 27, 2025 Server log from when you did that and the exact time?
AngelSing 49 Posted April 27, 2025 Author Posted April 27, 2025 (edited) 5 minutes ago, ebr said: Server log from when you did that and the exact time? embyserver.txt Approximately between 12:40 p.m. and 12:43 p.m. Edited April 27, 2025 by AngelSing
AngelSing 49 Posted April 27, 2025 Author Posted April 27, 2025 @ebrMaybe it is a problem that only affects Synology NAS devices, or could it be global? I do not have Emby on a Windows server to test it.
ebr 16354 Posted April 27, 2025 Posted April 27, 2025 It appears your server cannot access the necessary file location. System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/var/packages/EmbyServer/var/cache/images/enhanced-images/b/b47e9b62475b2be95272cbe6efa4d0d2.jpg'. System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/var/packages/EmbyServer/var/cache/images/enhanced-images/b/b47e9b62475b2be95272cbe6efa4d0d2.jpg'.
AngelSing 49 Posted April 27, 2025 Author Posted April 27, 2025 6 minutes ago, ebr said: It appears your server cannot access the necessary file location. System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/var/packages/EmbyServer/var/cache/images/enhanced-images/b/b47e9b62475b2be95272cbe6efa4d0d2.jpg'. System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/var/packages/EmbyServer/var/cache/images/enhanced-images/b/b47e9b62475b2be95272cbe6efa4d0d2.jpg'. The path is different from what appears in the directory. I do not see the var folder on the Emby server.
Luke 42289 Posted April 27, 2025 Posted April 27, 2025 On Synology you'll need to SSH into there: Emby Server Data Folder
AngelSing 49 Posted April 27, 2025 Author Posted April 27, 2025 (edited) 1 hour ago, Luke said: On Synology you'll need to SSH into there: Emby Server Data Folder Yes, it is correct, that is how I have it. However, according to the log reviewed by @ebr the plugin cannot access: /var/packages/EmbyServer/var/cache/images/enhanced-images. But first, it could never access it because in Synology the path does not start with /var, but with /volume1. And second, there is no var folder between EmbyServer and cache on Synology. Which makes me understand that the plugin is not working properly on Synology. Edited April 27, 2025 by AngelSing
Luke 42289 Posted April 27, 2025 Posted April 27, 2025 1 hour ago, AngelSing said: Yes, it is correct, that is how I have it. However, according to the log reviewed by @ebr the plugin cannot access: /var/packages/EmbyServer/var/cache/images/enhanced-images. But first, it could never access it because in Synology the path does not start with /var, but with /volume1. And second, there is no var folder between EmbyServer and cache on Synology. Which makes me understand that the plugin is not working properly on Synology. Perhaps var is just something virtual. But notice this in your server log: Data path: /var/packages/EmbyServer/var The server is using /var/packages/EmbyServer/var all over the place, and it obviously works just or the server wouldn't even be able to create a log file.
AngelSing 49 Posted April 28, 2025 Author Posted April 28, 2025 (edited) 5 hours ago, Luke said: Perhaps var is just something virtual. But notice this in your server log: Data path: /var/packages/EmbyServer/var The server is using /var/packages/EmbyServer/var all over the place, and it obviously works just or the server wouldn't even be able to create a log file. So, what exactly would the error be? Why is the plugin unable to replace the cache files? Why does it say it can't find the route? Edited April 28, 2025 by AngelSing
Happy2Play 9814 Posted April 28, 2025 Posted April 28, 2025 8 hours ago, AngelSing said: So, what exactly would the error be? Why is the plugin unable to replace the cache files? Why does it say it can't find the route? Did you verify the image exists? /cache/images/enhanced-images/b/b47e9b62475b2be95272cbe6efa4d0d2.jpg My guess would be the database recorded an image there and it is no longer there.
