Valdorama 1 Posted April 21, 2025 Posted April 21, 2025 I'm trying to evaluate Emby to use as a DVR and client for IPTV. I've been using IPTVEditor to trim and organize the set of channels from the IPTV provider. I've configured Emby so that both the channel source and guide is provided via IPTVEditor links. Emby processes the channel list OK but it cannot seem to handle the XMLTV guide data. This guide data works in other IPTV apps so I don't think the problem is the data. I see this in the Emby logs: 2025-04-21 22:56:54.642 Info TaskManager: Executing Refresh Guide 2025-04-21 22:56:54.642 Info Server: http/1.1 Response 200 to host1. Time: 48ms. POST http://10.0.0.2:8096/emby/LiveTv/ListingProviders?ValidateListings=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=5c7d3dea-ab10-4cf8-a5ee-4e7647f826da&X-Emby-Client-Version=4.8.11.0&X-Emby-Token=x_secret1_x&X-Emby-Language=en-gb&reqformat=json 2025-04-21 22:56:54.644 Info HttpClient: POST https://mb3admin.com/admin/service/registration/validate 2025-04-21 22:56:54.645 Info HttpClient: GET https://opop.pro/x_path1_x 2025-04-21 22:56:54.761 Info HttpClient: Http response 200 from https://mb3admin.com/admin/service/registration/validate after 117ms. Headers Server=nginx, Date=Mon, 21 Apr 2025 22:56:54 GMT, Connection=keep-alive, Access-Control-Allow-Origin=*, Access-Control-Allow-Headers=Content-Type, Range, Accept, X-Emby-Token, X-Admin-Token, X-Application, Access-Control-Allow-Methods=GET, POST, PUT, DELETE, OPTIONS, Cache-Control=no-store, must-revalidate, no-cache, Pragma=no-cache, Vary=Accept-Encoding 2025-04-21 22:56:54.763 Info SecurityManager: Registered for MBSupporter 2025-04-21 22:57:00.897 Info HttpClient: GetTempFileResponse url: https://opop.pro/x_path2_x 2025-04-21 22:57:00.897 Info HttpClient: GET https://opop.pro/x_path2_x 2025-04-21 22:57:03.023 Error LiveTvManager: Error getting channels *** Error Report *** Version: 4.8.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.8.0-52-generic (buildd@lcy02-amd64-046) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubunt Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 2 Data path: /config Application path: /system System.Xml.XmlException: System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: tv. Line 1, position 2862229. at Emby.XmlTV.XmlTvProvider.GetXmlDataCache(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.XmlTV.XmlTvProvider.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.RefreshEpgChannels(IListingsProvider provider, ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshEmbyChannelsInternal(IProgress`1 progress, CancellationToken cancellationToken) Source: Emby.XmlTV TargetSite: Void MoveNext() I've attached the guide data exactly as returned from the IPTVEditor guide URL (it returns a gzip). IPTVEditor_epg.xml (3).gzip
Luke 42241 Posted April 21, 2025 Posted April 21, 2025 Hi, what url did you configure into the guide data provider? is it valid xml?
Valdorama 1 Posted April 21, 2025 Author Posted April 21, 2025 It's the URL provided by IPTVEditor: It works in other applications (e.g. Channels DVR), and when I enter that URL in my browser, it downloads the gzip file (attached in the original post). The gzip does contain valid XML.
Luke 42241 Posted April 21, 2025 Posted April 21, 2025 Just now, Valdorama said: The gzip does contain valid XML. How did you confirm that?
Valdorama 1 Posted April 22, 2025 Author Posted April 22, 2025 I opened up the gzip and extracted the xml file. The xml looks valid and Notepad++ confirms it.
Valdorama 1 Posted April 22, 2025 Author Posted April 22, 2025 The 'Xml Tools' plug-in, and it's 'Check xml syntax' option.
Carlo 4561 Posted April 22, 2025 Posted April 22, 2025 Was this a one-time error, or does it happen every time you refresh guide data?
Valdorama 1 Posted April 22, 2025 Author Posted April 22, 2025 It happens every time. I've looked in the XML file and can't see what the issue could be - the "<tv>" element (as referenced in the error message) is definitely closed properly. The line and position don't seem to point to anything obvious.
Valdorama 1 Posted April 23, 2025 Author Posted April 23, 2025 Looks like I may have sorted this. The guide URL can also be specified as https://opop.pro/xxxxyyyyzzzz/?xml=1 which streams the raw XML data, rather than the default (without the param) which delivers the data in gzip-compressed format. Presumably Emby was having issues processing the gzipped content. The guide is properly populated now. 1
